Results 1 to 8 of 8
Thread: Adding a Winch on a Ram-Lin Trailer
    Feb 2009
    Hopkins, MN
    332
    Default Adding a Winch on a Ram-Lin Trailer
    What is the easiest way to retrofit a winch onto a Ram-Lin trailer that has the turnbuckle and the crash pad? I would like to add a winch without buying another bow stop.
    Thanks.
    1997 Ski Nautique
    Feb 2010
    Phoenix AZ
    921
    5
    i have the same exact question
    Eric, Phoenix AZ
    G23 550 hp (finally here)
    2002 Super Air
    Feb 2010
    Bostian Heights, NC
    582
    5
    thought has crossed my mind too ... havent had any luck finding ideas however
    2003 SANTE - "OG 210"
    Feb 2009
    Hopkins, MN
    332
    I'm starting to think it can't be done.
    1997 Ski Nautique
    May 2008
    Eau Claire, WI
    1,760
    I have just the opposite issue. I want to add crash pads to an Eagle trailer with winch. Anyone done that before? Sorry for the highjack!
    '12 200TE
    '08 196LE (previous)
    '07 196LE (previous)
    '06 196SE (previous)
    The only thing I can think of is to mimic the newer bow stops and I'm not even sure if it would work.
    Could you cut about 2 inches from the middle of the post then weld plates steel plates on either side and mount the winch on the outside like the newer bow stops? I have no idea if this would work or not but it's the only thing I could come up with and I have no idea how much it would cost to do.
    May 2010
    Knoxville, TN
    245
    5
    Any decent welder can knock out these changes in a day. I would suggest taking the whole rig to them to make a plan then splash the boat and let them work on the trailer alone. The other option would be to have them fabricate a bolt on part.
    I have a Ram-Lin trailer as a loaner and agree that the turnbuckle is a PITA.
    i have the same trailer and not being to fully tighten down the boat drives me up the wall, the slight bouncing action of the boat on the trailer worries the pi$$ out of me, luckily i only have to pull it about 15 miles each but still it annoys me, i was looking at it the other day and there really isn't anywhere to mount one unless it's right in the V of the trailer where the tongue goes through and even then you don't have anything to tighten it down to, the turn buckle sucks in my opinion and crash pads are ok until you get the boat so tight against them you can't put the dang cover back on
