Looks great - I was wondering if you could tell me how much i should budget for new skins + install like you did. Not trying to get in your business but have been considering it on my 2000 SN. Thanks.
Man oh man, this looks awesome!! You're making me think about doing similar to my PAN...Current : 2000 Pro Air Nautique, Silver&Black accents, pulled by 2012 black Chevy Tahoe
Previous: 1990 Ski Nautique
When upholstery goes in I'm sure I'll find myself recontemplating seadek all over again for the third time .... Looks really good and done right.
Jeff, did they spray the black gel coat directly over the raw fiberglass? Or did the fiberglass have to be sanded smooth first or preped in anyway with a skim coat to smooth the surface out in order to remove a lot of the "imprint" of the glass fibers to have a smooth surface to gel coat over?
when gel coat was sprayed was it thickened at all? To provide better fill and faster buildup? Did the gel coat then have to be polished after it was applied? This would help a lot of us who may follow your sea deck application and use gel coat instead of other alternatives.
A d m i n i s t r a t o r
- Mar 2002
- 16462
- Lake Norman
- Mooresville, NC
- 2025 SAN G23 PNE 1998 Ski Nautique 1985 Sea Nautique 1980 Twin-Engine Fish Nautique
The floor was sanded after the carpet was removed. It is a messy process, but it is necessary in order to smooth everything out and eliminate glue and carpet fibers. The gelcoat was then sprayed directly on the fiberglass. I am not sure if they thickened it, but I don't think so. It is not polished, so it isn't shiny. You could do that, but it really isn't necessary. Only a small part shows.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
- Mar 2002
- 16462
- Lake Norman
- Mooresville, NC
Got about half of the interior installed today. Had to make a couple of trips to the hardware store (funny how nuts and bolts go missing during these projects). I was hoping to get it all installed today, but it just didn't happen. Tomorrow's the day!
Hello Jeff! Congratulation to your project. Wonderful what you make possible. Because of the fact that I want to replace my carpet in a sn200 with SeaDeck I would like to know your experience. Do you think I can do it myself? What is the price only for the SeaDeck?
Thanx from Austria!
Looks awesome. I can only imagine the sense of accomplishment you must feel. The SeaDek looks amazing!!Current : 2000 Pro Air Nautique, Silver&Black accents, pulled by 2012 black Chevy Tahoe
- Mar 2002
- 16462
- Lake Norman
- Mooresville, NC
Interior is installed with the exception of the panel around the throttle arm. That one is being adjusted a bit by the upholstery installer tomorrow morning, after which it will be installed.
Tomorrow is water test day! Can't wait to get this boat out on the water!!
Jeff,
WOW!!!!that looks SO friging nice! !!
What an awesome job! !! I wish I was close to be able to see it in real life as opposed to pictures. ..cause I am sure it looks better for real! !!
Even the trailer looks good. ..can't drive a nice boat like that on a cappy trailer. .
The only thing missing now to finish it off perfectly is a set of Nautique sleeves on the guide posts.
Like others have said, 'I want that boat! '
Thumbs up to you, you should be proud. 👍👍
Sent from my SM-G900W8 using PLANETNAUTIQUE mobile app
- Mar 2002
- 16462
- Lake Norman
- Mooresville, NC
Thank you! The trailer is actually pretty bad. I will probably have Ram-Lin make a nice dual-axle trailer for it in green with electric brakes sometime this winter. The current trailer is a $600 special that the local dealer just happened to have on the lot. It is functional, but that's about it.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
Originally posted by NautiqueJeffThank you! The trailer is actually pretty bad. I will probably have Ram-Lin make a nice dual-axle trailer for it in green with electric brakes sometime this winter. The current trailer is a $600 special that the local dealer just happened to have on the lot. It is functional, but that's about it.
