Does anyone know the part number for the oil filter in a wix filter? I need to change my oil here real soon and would appreciated it if someone knew. Thanks!
oil filter part# for EX 343
'08 SAN 210 Team Black w/Patriot red top stripe-Tow Biminis over the tower-4 under water transom lights-hot/cold shower-crest carpet-full throttle steering wheel-extra 6 channel JL amp-Pro 80's-WS420-fiberglass sub enclosure-led'd vents-Chromax Letters-and Tinted windshield for now......
Tow Vehicle--05 GMC 2500 Crew Cab Short Bed 6.6L Duramax/Allison with a few mods
-GO DAWGS!-Tags: None
RE: oil filter part# for EX 343
Don't the PCM's all use the Ford filter on the remote kits? Motorcraft FL1A Napa Gold 1515 etc
Aren't NAPA's filters Wix filters ?
I could be wrong here so wait to see what others say, but I put a PCM remote kit on my 502 a couple years ago and thought they were all the old Ford ones.the WakeSlayer
1968 Correct Craft Mustang
Re: RE: oil filter part# for EX 343
Originally posted by WakeSlayerDon't the PCM's all use the Ford filter on the remote kits? Motorcraft FL1A Napa Gold 1515 etc
That would be really interesting! Ford filter with a Chevy block!'08 SAN 210 Team Black w/Patriot red top stripe-Tow Biminis over the tower-4 under water transom lights-hot/cold shower-crest carpet-full throttle steering wheel-extra 6 channel JL amp-Pro 80's-WS420-fiberglass sub enclosure-led'd vents-Chromax Letters-and Tinted windshield for now......
-GO DAWGS!-
RE: Re: RE: oil filter part# for EX 343
I guess I worded that poorly. What i meant to say is: I could be wrong about the newer ones, such as the 2008 SAN.
I am positive about the Ford Filters on the the earlier remote kits. Including on Chevy's.
The Ford filter definitely makes my 502 just a bit faster.the WakeSlayer
yes, the 343 uses the Ford filter.....i put a K&N filter (HP3001) on my 343 and it works just fine
http://www.planetnautique.com/index....&view=next
ACDELCO Part # PF2
WIX Part # 51515 (black color - matches engine nicely)
Motorcraft Part # FL1A
Purolator PL30001
FRAM Part # PH8A (junk)
If your brand is not there, look up a filter for a 1990 Ford F-150 with a 302 V8.
I do not know why, but years ago somebody decided remote filter mounts would use a Ford filter. I had a Ford (Motorcraft FL1-A) filter on my VW powered dune buggy, that I modified to a full flow oil filter. The standard has stuck.
My 1966 Ford pickup, my 1974 Ford pickup, my 1996 Ford Aerostar, and my 1997 Ski Nautique all take the same oil filter.
You can get them at Wal-Mart for less than $4.00. Sales tax may be extra, but my state does not have sales tax.
The following engines of mine take the same FL1A Ford filter
1999 Super Air PCM 502 (chevy)
1968 CC Mustang 289 Interceptor
1967 Ford Mustang 289 Ford
1958 Allis Chalmers D17 tractor
makes it easy.the WakeSlayer
