PP Install on 95 Super Sport+Tip
  • wake_fun
    • 1330
    • CA
    • 1995 Super Sport
    I installed PP this past weekend. I used two VERY strong little magnets, one in the boat and the other magnet under. I could move them around and then visually check underneath to see where I was at. Once I got it right I outlined the magnet in the boat with a felt pin and new exactly where to drill my pilot hole. Once that was done I went back under and drilled the 2" hole up into the boat. I used a lot of masking tape and the hole came out perfect!
    Photo Album
    Ballast Install 1
    Ballast Install 2
    Amp Install
    PPass Install
    Alternator Install
  • actiondcpd
    • Jan 2004
    • 147
    • Cardiff, CA
    RE: PP Install on 95 Super Sport+Tip
    Great idea. Looks like a clean install too. Have you water tested yet?
    • wake_fun
      • 1330
      • CA
      • 1995 Super Sport
      Re: RE: PP Install on 95 Super Sport+Tip
      Thanks.
      I haven't had it out yet. My interior is torn all apart doing stereo stuff right now. I'm dying to try it out though!
      Photo Album
      Ballast Install 1
      Ballast Install 2
      Amp Install
      PPass Install
      Alternator Install
      • sperbet
        • Aug 2004
        • 283
        • Truckee, CA
        wake_fun, you are the man. Those pictures are going to help me out a bunch. Thanks!!!
        Ummm, I\'ll take the REAL 210 please. Thanks.
        • wake_fun
          • 1330
          • CA
          • 1995 Super Sport
          Your welcome :grin:
          Photo Album
          Ballast Install 1
          Ballast Install 2
          Amp Install
          PPass Install
          Alternator Install
          • wviveen
            • Dec 2004
            • 133
            • Santa Monica
            • 2016 Nautique G23
            That is a great tip... Thanks i will be using that, i will be installing pp in my supersport shortly.
            • actiondcpd
              • Jan 2004
              • 147
              • Cardiff, CA
              Don't forget to post some pictures of the stereo install!
              • Wakecat
                • Mar 2005
                • 25
                • Orlando
                • 2014 210
                Nice pic's. Did you just use a 2" hole saw? How hard was the rest of the install? I want to install one myself but not too sure about the actual connections at the engine side. Thanks for any help.
                • wake_fun
                  • 1330
                  • CA
                  • 1995 Super Sport
                  2" hole saw.
                  It is VERY easy. All wires come with connectors. Just plug everything together. The connections on the engine were easy, just follow the directions and make sure you put the little washer on the right side (you will know what I'm talking about if you do it.
                  Photo Album
                  Ballast Install 1
                  Ballast Install 2
                  Amp Install
                  PPass Install
                  Alternator Install
                  • wake_fun
                    • 1330
                    • CA
                    • 1995 Super Sport
                    Three years have gone by and it's still perfect. I haven't had to mess with anything!
                    Photo Album
                    Ballast Install 1
                    Ballast Install 2
                    Amp Install
                    PPass Install
                    Alternator Install
                    • WakeSlayer
                      • Sep 2005
                      • 2069
                      • Silver Creek, MN
                      • 1968 Mustang
                      nice job with the magnet idea!!! When we installed mine, we were about 1/8 inch off. I had to fab a washer to put under the the outside part to give me enough space inside to get the nut over the top. In my defense I had my contracted boat hole driller do the drilling, as always. (I hate the very idea) I suggested measuring 20 times, etc and noted where we needed clearance, and how much. He only measured 19 times....
                      the WakeSlayer
                      1968 Correct Craft Mustang
                      • wake_fun
                        • 1330
                        • CA
                        • 1995 Super Sport
                        Sucks that the hole was off...................but the other part was some funny sh!t Yellow_Flash_Colorz:
                        Photo Album
                        Ballast Install 1
                        Ballast Install 2
                        Amp Install
                        PPass Install
                        Alternator Install
                        • WakeSlayer
                          • Sep 2005
                          • 2069
                          • Silver Creek, MN
                          • 1968 Mustang
                          Much funnier now than at the time, let me assure you. Yellow_Flash_Colorz:
                          It worked out. We ended up using a cutting board for chopping veggies, and cut out a washer, drilled it the right size, sanded it thinner, beveled the edges, and so on. We still refer to it as the Nautique Repair Kit. The only consequence is that my speedo on the PP reads a little low when running the boat full speed.
                          the WakeSlayer
                          • wake_fun
                            • 1330
                            • CA
                            • 1995 Super Sport
                            So were you to close to the gas tank and it wouldn't fit?
                            Photo Album
                            Ballast Install 1
                            Ballast Install 2
                            Amp Install
                            PPass Install
                            Alternator Install
                            • WakeSlayer
                              • Sep 2005
                              • 2069
                              • Silver Creek, MN
                              • 1968 Mustang
                              no, just under the trans mount, if memory serves. Look at your pic #3511, closer to the metal bracket. not enough room to have the housing sit in there, that is why we had to extend it out 1/4 inch.
                              the WakeSlayer
