Is there a way to reset or calibrate the Faria surface water temp reading on my 08 210 SANTE? My reading is currently 10 degrees colder than actual but my air temp is accurate.
I have never seen a way to adjust. You can contact faria to double check. But I think you would have to replace the sensor. Which I think is combined with the paddle wheel.
http://faria-instruments.com/product...dGauge=4_trans
I have same boat and I think in our year the gauge speed is paddle wheel and is combined with water temp sensor. And then we also have a depth only transducer...
I think it is this one:
SN0015 - Thru-hull Flush Mounted Temperature and Speed Sender
Perfect for water sports which require continuous accurate speed measurements like water-skiing, where boat angles can sometimes interrupt transom mounted senders.The thru-hull flush mounted temperature and speed sender offer virtually no drag. Easy installation and accuracy makes this sender the perfect choice for water sports.
