Knock Sensor Failure?
  • jwhposon
    • Mar 2005
    • 159
    • Oregon
    I have a 2004 SAN with 660 hrs. Over time the original knock sensor sort of deteriated. On the port side of the engine down towards the bottom under the sparkplugs - this is where the knock sensor is. When I replaced it with a new one I continue to get this failure message on the dash and it says take it to a dealer. I don't hear anything different than before, no knocks, pings, etc... Engine runs GREAT. Outside of maybe getting a bad sensor is there something else I am not thinking about?
  • jwhposon
    • Mar 2005
    • 159
    • Oregon
    bump
    • NCH2oSki
      • 1159
      • Maryville, TN
      • 2005 ski nautique 206 SE
      Did you install it with any thread sealant or tape? If so that could be the problem, otherwise I have no ideas.
      Prior Boats:
      1999 Ski Nautique GT-40
      www.skiersofknoxville.org
      • rcazwillis
        • Feb 2014
        • 117
        • Fort Worth, TX
        • 2002 SANTE
        Do error codes clear when the issue is resolved. On obdii, you have to clear the code after replacing the part.
        Sent from my SM-G900V using Tapatalk
        • jonsquatch
          • Jul 2012
          • 251
          • AZ
          • 2012 Super Air Nautique Byerly Icon
          What motor is it Ford or GM? You should have 2 knock sensors, were both replaced? Even new sensors could be bad and then there is also the harness and the ECM or PCM or whatever they call the generation of computer you have that could be the culprit.
          For most GM knock sensors you could through a multi-meter on them, resistance should usually be somewhere between 93-107 kohms and when there is a knock they should output ac voltage you can tap on the side of the block and see if you get any readings from each of them, they should be about the same, if not you should be able to find the culprit. If you can figure out what wire it is at the ECM you can test again from there to rule out any shorts in the line. If everything else tests out fine I would probably replace them both again before trying to replace the ECM.
          2012 Super Air Nautique 210 Byerly Icon Edition EX343 <-- Current Boat
          2007 Reinell 185 BR Volvo Penta 4.3GL <-- Former Boat
          1988 Bayliner 195 Capri OMC Cobra 5.0 <-- Former "starter" Boat
          • jwhposon
            • Mar 2005
            • 159
            • Oregon
            I only replaced the one knock sensor just behind the starter and the belts on port side of engine. There is only one wire attaching to the knock sensor and Active Water Sports said I had to bring it to them to clear the computer - it takes a special something? Is there an odbii plug because I could not find it? I have a scanner that I can use to reset but couldn't find the port. The engine runs perfect and the only other thing i did was replace the fuel filter - no issues there. If I plug the old sensor in the error clears - but that sensor is half eroded away. It is torqued to correct specs and I did not use any teflon tape or any other sealant. I still have the error even after letting it sit with batteries disconnected for hours... any help is appreciated.
            • ski4evr
              • May 2010
              • 613
              • Bowling Green, KY
              • 2005 SV 211
              Check the resistance with an ohm meter from the single pin input to the ground "threads" on both sensors. If the old one clears the code, then the new one should have the same resistance or it is the wrong part, if I am thinking right. Haven't ever tried this, and not sure if it works like a temp sensor, but worth a try.
              2005 SV-211
              • slob02
                • Sep 2003
                • 333
                I had to have a dealer reset mine with their lap top after I replaced it.
                2008 Super Air 210 Team
                2004 AIR 206 Team
                1997 Ski Nautique 196
                1993 Ski Nautique SNOB
                • jwhposon
                  • Mar 2005
                  • 159
                  • Oregon
                  great news!!! As I was playing around with all the buttons I discovered that after pushing and holding the "M" button on the left gauge for 30 seconds it went away- which is the RPM's and the digital provides voltage, et, etc... The contact dealer message went away and we have had it out three times with no message. Thank you all for all your suggestions and support - not sure if this is the "right fix" but it seems to be working.
