Discerning a Pro Air from Air Nautique
  • PK
    • May 2006
    • 9
    I'm interested in late 90's Air Nautique, but not the Pro model. Beyond graphics, how can I tell difference? Are there some hull comparisions I can make? Anyone have pictures they can share?
    Also, any issues with the Air that I should ask seller or check into?
  • Quinner
    • Apr 2004
    • 2246
    • Unknown
    • Correct Crafts
    The Pro will have Rib's or Chines (if that is the correct term) in the Hull running front to back, very similar to what you see on Barefoot Nautiques. The Pro Hull is called "TWC" for Total Wake Control, the other hull is a "TSC" for Total Surface Control. Should be pretty obvious when you see the boat.
    I had a 99' Air with TSC Hull & GT-40 for about 5yrs & 500+hrs, it was a great boat. The only issues I had were the ballast pumps, trunk lock cable & depth gauge. The first Gen tower will not fit under a standard garage door even when folded.
    Check out the 99' brochure on www.correctcraftfan.com
    • Hollywood
      • Sep 2003
      • 1930
      • WIIL
      Chine is not the correct term, they are lifting strakes. The chine on a ski boat is the edge where the bottom hull surface meets the sides.
      • bobchris
        Banned
        • Apr 2006
        • 359
        what HW getting technicall on us what's the world coming too.
        • TRBenj
          • May 2005
          • 1681
          • NWCT
          Well we can still rely on your grammer and spelling... so its not Armageddon yet!
          1990 Ski Nautique
          NWCT
          • bobchris
            Banned
            • Apr 2006
            • 359
            dman spell check never works
