replacement foam
  • dantheman
    • Jun 2006
    • 39
    • Jasper, GA
    replacement foam
    I am looking for the foam tubes that go over the pvc boat guides for a late model trailer. I have been to every hardware store, the largest size they carry is for a piece of 1" pvc....
    My next thought are trying to find a couple kids floating "noodles" that are the right size. They are going to be covered by the black Nautiques covers anyways.
    Thanks for any input
  • SkiTower
    • 2172
    • Clayton, NC
    RE: replacement foam
    Whitelake has them in the store. I would imagine most dealers do.
    http://www.shopwhitelake.com/trgupa.html
    2007 SV211 SE
    Tow Vehicle 2019 Tundra
    Dealer: www.Whitelake.com
    • TRDon
      • Oct 2007
      • 722
      • MN
      I just bought new ones from the dealer. They wer cheap enough but I know if you really wanted to, you could go to a plumbing supply house because they have all sizes of foam insulation/pipe wraps. You will pay a grip for it if you arent a contractor though so you myay be better off buying new pylon covers.
      • bscott
        • 188
        • Bolingbrook, IL
        Join CCFan.com. You can buy through them.
        • jward
          • Feb 2008
          • 620
          • Sweet Home Alabama
          • 03 SANTE 04 SANTE
          I was in a local hardware store today and saw the same foam used on trailer guides. It was 2" pvc pipe insulation foam. They had it for $5 per 6 ft piece. Hope that helps
          • dantheman
            • Jun 2006
            • 39
            • Jasper, GA
            thanks for all the input!
            I was able to find a 6' stick of foam pipe insulation the has an ID of 2 3/8" it worked perfect, my "Nautique" covers were in perfect shape, so I just transfered them to the new foam. I picked up the foam at large plumbing and electrical supply place for contractors. I checked all the local hardware stores with no luck. It was only $7.00, that is enough for both sides
