Took the boat out today and had a great time. Dumped the tanks and headead to the trailer. When I got to the dock I noticed that my starbord tank did not empty. I had put some gear in the sorage over the tank and it pulled a wire out of the plug on the empty pump. I cut the wires away from the plug and just twisted them back in place eliminating the plugins. Tried to turn on the pump again and nothing. Checked the breaker and found that it had popped out. Pushed it back in and now it works but only for about 10 sec before it trips the breaker again. When I push the breaker button in and turn on the pump you can see the volt meter going down which eventually trips the breaker. Any suggestions???? I tried to see if metal was touching any of the wiring but couldn't find anything.
Justin
Justin
