Supra
  • Nidal
    • Aug 2008
    • 2
    • Houston, TX
    Supra
    Jonfo Nailed it on the head:
    - Rotary dial volume control on stereo remotes. pushing multiple times for volume up or down sucks.
    - RPM sensitive volume control like all GM vehicles have had for 10+ years. This would eliminate the contstant volume up/volume down every time a rider gets up/falls.
    - Design the hull so it isnt so side-to-side sensitive to weight placement (like my 220). Or, maybe put a balance sensor in it that would move a 100lb weight from side to side to counter it.
    - I like the garbage bin idea on the 220, it was a feature i didnt expect i would like so much. they should try to incorporate that into all models, even if it is smaller.
    - have auxilliary sack connectors to add extra ballast bags without having to plumb it ourselves. (but they probably can't do this due to liability reasons)
