Surf setup for a SANTE 220
  • brad_s
    • Jan 2008
    • 26
    I was interested in hearing how you setup your 220 for surfing?
  • jonfo
    • 385
    • Bellevue, WA
    • 1990 SN 2016 G23
    RE: Surf setup for a SANTE 220
    In my 220 i have 2 sacs in back in the lockers on top of the stock tanks, and one in the center floor locker. They are all fly high pro x series sacs and completely fill the cavity when full. i keep the stock center tank + center sac full, plus the port tank and vdrive sac full. everything on starboard empty. reverse port/starboard to ride on the other side. This works well, but its best to have about 4 people in the boat on whatever side the weight is on, otherwise you may need another sac on that side. I go about 11mph, or a bit faster depending on if there is more people/weight. I keep the wake plate lever all the way forward in the slalom position, this is important. The other thing to consider is the rider's weight and the board they are on. The less the rider weighs the less wake it takes them to keep moving. The larger and faster the board is the less wake size it takes as well, so you have to factor these things in to determine the optimal weight setup for your rig.
    -Jon
    16 G23
    07 220 TE
    05 211 TE
    95 SS (210)
    89 SN
