06 210 wake
  • pablo
    • Jun 2008
    • 30
    06 210 wake
    I already asked this question earlier but just curious how people set this boat up with additional ballast. I would like to make the wake bigger and a bit more rampy. Is this possible by adding weight up front or should i add weight in the back on top of the factory tanks? How do most people set this boat up with extra weight? I like to ride in the morning before work with just one or two other guys so i really need to add some extra weight. What type of weight would you recommend? Is the Tsunami 1200 pump alot faster than the other ones on the market and would it work well with a different brand sack like fat buddies? The obvious reason is they are alot cheaper. Thanks for any advice.
  • Puckhead
    • Aug 2004
    • 53
    • Austin, Texas
    • 1998 Air Nautique 2006 201 SANTE
    RE: 06 210 wake
    I put a an additional 440 up on the floor in the bow and one or two 300lbs (fat buddies) on the floor depending on how many people are in the boat. I use an Ubr pump that fills/empties them pretty quick.
