Towing a Parasail w/ Nautique?
  • mav7
    • Jun 2006
    • 30
    Just curious if anyone here has successfully pulled a parasail with a Nautique. We have a 2006 Air Nautique 216 and are thinking about towing a parasail. Will the lift of the parasail be too much for the tow hook / boat to handle?
    Please share some of your experiences with this!
    Thanks,
    Mike
  • zapada
    • Jul 2008
    • 112
    • Sun Valley, ID
    RE: Towing a Parasail w/ Nautique?
    If you're worried about the pressure from the pull use the lifting ring. Those are designed to hold the entire weight of the boat. However, they are designed to do that when lifted straight up. The boat can certainly handle it. We've pulled the kite tubes and the new wakeboard kites from the tower and pylon. It seemed to handle those pressures and forces just like normal.
    • mav7
      • Jun 2006
      • 30
      Re: RE: Towing a Parasail w/ Nautique?
      Yes I was definitely going to use the lifting ring.. since with our pylon there is really no way to secure the line if it is extended above the boat. I read on one post here where a parasail lifted the prop out of the water...
      I guess I just want to make sure the boat and lift hook are ok to tow upwards of 12,000lbs. (according to http://www.ehow.com/how_8987_outfit-...rasailing.html)
      And of course if anyone has any stories/experiences share away
      Mike
      • SkiTower
        • 2172
        • Clayton, NC
        It says right on the boat not to hook kites and stuff up. Don't know if you're looking for practicality or legally, but I'd check the books before I invalidated any warranties.
        And I'd be worried about hooking 12,000 lbs to my boat. the lifting rings are designed to lift the boat straight up (3500 lbs / 2 rings = 1750 lbs *5 safety factor = 8750 lbs)
        2007 SV211 SE
        Tow Vehicle 2019 Tundra
        Dealer: www.Whitelake.com
        • darrel409
          • Jul 2004
          • 566
          • San Dimas, So. Cal
          We used to pull our parachute with an 81SN, from the pylon. Only did it 15-20 times and never had any problems. I dont know how much force we were pulling around lbs-wise. Now older and a little wiser...might not do it.
          • mav7
            • Jun 2006
            • 30
            I am not sure if 12,000lbs is accurate on that website.. maybe on a larger parasail with multiple people that is possible. My friend claims there will be a max of 1000lbs on the hook with 1 person... I just wish I could find more resources on how to calculate this.
            • Gizmo
              • Jun 2006
              • 54
              • Grapevine Texas
              The boat weighs approx 3000 lbs, and the added thrust from propulsion......
              I have no idea what the actuall load rating is for the lift ring.
              That might be something to think about.
              • Nbigger
                • Mar 2008
                • 79
                • Fenton, MI
                I have been pulled around lake michigan on a freinds 2001 model. we had no problems but I can not remember where the hooked the line.
                  • 2908
                  Don't use the lifting ring, you won't be able to steer if a wind gust comes up. Use the center pylon. It is against all CC rules, voids warranties, etc. Make sure the pylon is tight. Do not tow it from the tower if it has one.
                  • JUST-IN-TIME
                    • 293
                    • ON YOUR BOAT
                    [quote="Mikeski"]Doni would not
                    the boat could easily flip over with a gust of wind
                    i have heard horror stories
                    HUMAN BUILT = HUMAN FIXED
                    switchbait.com
                    • udlax2181
                      • Aug 2005
                      • 9
                      • Saranac Lake, NY
                      yup
                      Yeah, we used to do this all the time from the pylon. Proceed at your own risk though...
                      • wakeskier
                        • Oct 2007
                        • 77
                        • Massachusetts
                        • 2008 Super Air Nautique 210
                        I just got back from vacation at Lake George, NY
                        I noticed there's a parasail company there that exclusively tows with 1980's barefoor nautiques from the center pylon.
                        They've been doing it forever, apparently it works...
                        • saceone
                          • 650
                          • Montréal
                          ^^ I'm sure it works...but it's also less frustrating to flip over a 1980 than a 2000+ SANTE.
                          my 2cents.
                            • 2908
                            Just-in-time,
                            "easily flip over" - I doubt it.
                            Possible yes, anything is possible. I am sure you can find an example of it, just as you can find examples of people getting hit by lightning. We used to have a parasail and towed it from the center pylon.
                            Just curious, do you have the experience towing a parasail behind your own boat or are you speaking hear-say?
                            Just like anything else, you need to use common sense, don't do on windy days, don't get the flier too high, don't drive close to shore/other boats, etc.
                            I actually got rid of mine once I got old enough to understand the liability I was exposing myself to.
                            • 01skinautiqueGT40
                              • 117
                              it says on the pylon not do pull parasailes and all that ****. these boats are made for watersports and thats what they do best, if i was you bossman. i wouldnt push the limits your asking for trouble
                              CC Owned
                              1978 Ski Tique
                              1989 Ski Nautique 2001
                              1996 Ski Nautique 196
                              1999 Super Air Nautique (Python Powered)
                              2001 Ski Nautique 196 PCM GT-40 25Th Anniversary Current Boat PP Digital Pro 150 ORIGINAL Hours ( Current Model On The Lift )
                              Tow Rigs,
                              2002 Ford F-350 SRW Lariat 4X4 Crew Cab (Lifted 8" With 24" KMC ROCKSTARS ) ( Gotta Love Diesel Prices , That V10 Sounds Mighty Fine Right Now )
                              2007 Chevrolet Suburban 1500 6.0L LTZ 4X4 ( Bone Stock )
