For your high idle problem... be sure to check your throttle cable. I had a similar problem with an older boat and it turned out that the throtle cable was hanging up when i let off of the throttle. When i shut down the engine it would free up and return to normal idle rpm... I realigned the cable and added a zip tie and all was well.
