pulling 02 210sante with a JEEP?
  • saceone
    • 650
    • Montréal
    can it be done without breaking anything?
    08 wrangler (probably rubicon)
    4 door
    rated at 5200lbs...
    would be equipped with a manual tranny..
  • 81nautique
    • Feb 2006
    • 257
    • Big Rock, Illinois
    • 2012 200 Sport 1956 Correct Craft Collegian Past boats 1955 Correct Craft Hurricane 81 Anniversary Nautique 1960 GlassCraft Ski Nautique #1
    RE: pulling 02 210sante with a JEEP?
    Thats a lot of boat to handle with that short wheel base and relatively light vehicle. I tow my smaller Nautique with a Liberty and it handles that very well but I don't think it would handle another 1000 lbs of boat very well.
    • saceone
      • 650
      • Montréal
      yeah that's what I was thinking :S
      • CradGen2
        • Aug 2020
        • 1343
        • Horseheads NY
        Wheel base and axle ratio are the key. I'd say a couple mile not and issue. More then 10 you'd be taking your life in your hands. I wouldn't but that's me.
        • AirTool
          • 4049
          • Katy, Texas
          Re: pulling 02 210sante with a JEEP?
          4 door
          rated at 5200lbs...
          If it's raining, don't expect any of your brakes to work.
          AirTool
          • Bullet
            • Jan 2006
            • 293
            • Somewhere
            • 2016 SAN 210
            RE: Re: pulling 02 210sante with a JEEP?
            you will be fine---just take it easy and dont get in a hurry
            2008 SANTE 220 (current)
            2004 SANTE 210 (gone)
            1998 BAJA 252(gone)
            1998 MALUBU WAKESETTER LX(gone)
            2000 CARLSON (gone)
            1992 MC MARISTAR 240 (gone)
            1994 GLASTRON 175 (gone)
            • zeeto
              • Jul 2008
              • 6
              • JohnsonCity, NY
              4 door has a pretty decent wheelbase, and the Rubi will come with 4.10s, but you could easily have them upgraded to 4.56s or higher...
              • ranger3
                • Mar 2008
                • 73
                I don't think it would be much fun and hills will kill you. Of course it will pull the weight, but you would have a hard time stopping quickly or taking any evasive action.
                • Quinner
                  • 2246
                  • Correct Crafts
                  Re: RE: Re: pulling 02 210sante with a JEEP?
                  Totally agree. Just like your boat, fully loaded it will not handle as well, feel sluggish, etc. If the vehicle is properly equipped and rated for the load then what's the problem?
                  Would not put much thought into the "No brakes in the rain" comment, however it would be interesting to hear some theory behind that comment.
                  • Ski-me
                    • Apr 2008
                    • 20
                    • Colorado
                    RE: Re: RE: Re: pulling 02 210sante with a JEEP?
                    How far are you going to be pulling it?
                      You can tow it. Would you be safer with a larger vehicle? Probably. I would put disk brakes on the trailer, if it does not have them already, on both axles, if necessary. Disk brakes are less affected by water, and rain on them.
                      I have moved "classic" Super Air 210's with my Ford Aerostar van. Same boat as what you want to move. I did not go long distances, or over any mountians, just local tows around the Portland, OR. area.
                      I have towed my 1997 Ski Nautique around the Pacific Northwest, and down to Lake Shasta several times.
                      Do not be in a hurry, and leave a lot of following distance. Keep an eye out for other idiots on the road, and you should be fine.
                      • Ski-me
                        • Apr 2008
                        • 20
                        • Colorado
                        Even though it's not hitched, I believe this guy uses his Jeep to haul his MC short distances. Longer wheelbase is much better but if the distances are short, the Jeep is probably fine. Changing gears to 4:56 probably isn't very cost effective.
                        [/img]
                        • wakeskier
                          • Oct 2007
                          • 77
                          • Massachusetts
                          • 2008 Super Air Nautique 210
                          I regularly pull my '03 SANTE 30m each way with my Cherokee Classic and it gets the job done. (Of course a larger vehicle would be ideal.) It's not the quickest vehicle, but get it in the right gear (it's a tank at 3000 rpms) and it won't even slow going up hills
                          I do have disc brakes on my trailer
                          (been pulling boats with it though since I bought it new 8 years ago)
                          4WD, 4.0L
                          I do use a weight distributing hitch though (check your owners manual, I've noticed Jeeps require this to reach the max towing capacity)
                          Your Jeep is rated for 200lbs more than mine, so it should get the job done ok
                          • saceone
                            • 650
                            • Montréal
                            thanks for all the replies guys.
                            I don't own the jeep yet...I am considering getting one soon..currently driving a 07 2.5 vw rabbit. I just need a truck
                            • ranger3
                              • Mar 2008
                              • 73
                              Re: RE: Re: RE: Re: pulling 02 210sante with a JEEP?
                              [/img]
                              That is a sweet looking rig.
