I am wondering if anyone has any Bf Goodrich radial t/a's on there trailers? I have always liked the looks of those tires. They run lower pressures than most trailer tires. 35psi I think most trailer tires are around 50psi? I just don't want to overload these tires. I don't think it will be cause a boat isn't much more that a car.
RE: Tire
I'm not a tire expert but typically trailer tires have a stiffer sidewall to reduce sway and handle a higher load rating in similarly sized tires. I ran passenger tires on my previous tandem axle trailer for 15 years with no issues but you would have to pay attention to the load ratings to reduce risk of premature blowouts or wear. Might be an idea to check into insurance requirements prior to running them as well in case a blowout caused an accident and someone decided the tires were not up to the task. I have trailer tires on my new tandem axle now and it does seem to ride different. JMO.
RE: Tire
Don't use car tires on your trailer. You'll be asking for trouble.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
Current Boats โ> 2025 Super Air Nautique G23 -- 2001 Ski Nautique -- 2000 Nautique Super Sport PYTHON -- 2000 Nautique Super Sport -- 1999 Ski Nautique PYTHON-- 1985 Sea Nautique 2700 (Twin-Engine, 1 of 13) -- 1981 Fish Nautique (Twin-Engine, 1 of 4) -- 1980 Fish Nautique (Twin-Engine, 1 of 4)
Former Boats โ> 2024 Super Air Nautique G23 PARAGON -- 2023 Super Air Nautique G23 -- โ2022 Super Air Nautique G23 PARAGON -- 2021 Super Air Nautique G23 -- 2021 Super Air Nautique G23 -- 2020 Super Air Nautique G23 -- 2019 Super Air Nautique G23 -- 2018 Super Air Nautique G23-- 2018 SAN 210 TEโ -- 2017 Super Air Nautique G23 -- 2016 Super Air Nautique G23 -- 2015 Super Air Nautique G23 -- 2014 Super Air Nautique G23 -- 2014 Super Air Nautique 230 Team Edition โ 2013 Super Air Nautique G23 โ 2012 Super Air Nautique 210 Team Edition โ 2011 Super Air Nautique 210 Team Edition โ 2010 Super Air Nautique 210 Team Edition โ 2008 Super Air Nautique 230 Team Edition โ 2007 Air Nautique 236 Team Edition -- 2007 Air Nautique SV-211 -- 2005 SV-211โ -- 2003 Super Air Nautique 210 Team Edition -- 2003 Air Nautique 226 -- 2003 Sport Nautique 216 -- 2003 Ski Nautique 196 -- 2003 Ski Nautique 196โ-- 2002 Ski Nautiqueโ -- 2001 Sport Nautique -- 2001 Ski Nautique -- 2000 Sport Nautiqueโ --โ 1999 Ski Nautique Open Bow -- 1999 Air Tique 176 -- 1998 Ski Nautiqueโ -- 1998 Ski Nautique -- 1998 Ski Nautique -- 1997 Ski Nautique -- 1997 Ski Nautique -- 1996 Ski Nautique Open Bow -- โ1994 Ski Nautique -- 1993 Barefoot Nautique -- 1983 Fish Nautique (TWIN ENGINE, 1 of 4) -- 1981 Fish Nautique (SINGLE ENGINE)
Tires are made for specific jobs. You need to have trailer tires on your trailer. First, their side walls are must stiffer. This reduces flex in the tire, which in turn reduces heat. I have not seen a radial trailer tire (that doesn't mean they aren't made), but radial construction helps the ride of your car. Using car tires on your trailer will work, but not recommended. Over time, or on a trip, car tires will overheat and have premature failures.
Boats and trailers are too expensive to use the wrong tires. The difference in price between car and trailer tires is minimal. If you want to improve the look of your trailer, get new wheels.
Goodyear Marathons are of radial construction as are most semi truck tires. Stick with a tire designed specifically for trailers.2018 200 Team H6
2009 196 Team ZR 409
2005 196 Limited ZR 375
2003 196 Limited Excalibur
1999 196 Masters Edition
1987 ProStar 190
Had a tire store once tell me you should not mix tire types between the tow vehicle and the trailer, if tow vehicle runs radials so should the trailer, always wondered if that was fact or fiction.
What about some of these trailers with the taller rims, 20's or whatever, or as another example the BU corvette boat with the big corvette wheels, are those "trailer" tires used in those applications?
Sure are, but it sounds like your tire shop was out of trailer tires... From what I understand trailer tires should have the stiffer walls and a higher weight rating. I think there's more front to back action on regular tires due to acceleration, or some such nonsense...Travis Fling
Choctaw Lake
Im gonna call BS on the tires matching that of the tow vehicle. It shouldnt matter.
Id be more inclined to run trailer tires on a single axle trailer, though Ive seen car tires with the proper load ratings used before without issue. Ive always read that you can run car tires on a tandem safely- but dont mix and match car/trailer tires at the same time. My last tandem came all the way across the country (AZ to Chicago to CT) on car tires. I ended up replacing them with Marathons, but Im leaning towards car tires for my new tandem. Actually Im planning on going with the BFG Radial TA's as well.1990 Ski Nautique
NWCT
Buy Goodyear Marathons and be done with it!
I thinks its preferable to have "trailer" tires but not a necessity. What you have to look at is that the load rating is equal to the amount of weight on the axle.
Remember that a car has 4 weight bearing points while a single axel trailer only has 2, so it will require double the load rating of a passenger car tire carying equal weight.
If you get the correct load rating, the tire will ahve sufficient sidewall strength regarless if its labeled as a "truck" or "trailer" tire
I see so its probably not worth it to put them on. Understandable. The tires I want are rated for 1750lbs a tire which should be lots. I only want to change the tires is because of the raised white lettering on the Radial t/a.2008 SANTE 210 Orange Baby! Current
2007 Gekko GTO22 Previous
