Correct Prop for 2000 Ski Nautique 196
  • Nautibouys
    • Dec 2008
    • 76
    • 2000 Ski Nautique 196
    Can anyone give any insight as to standard prop sizing for a 2000 SN 196. The one I just got when I bought my boat from a dealer used was a OJ 4blade 13x16P. Can't make out the cup on it. Is this too much pitch for this boat? What's a better all around choice?
  • NCH2oSki
    • 1159
    • Maryville, TN
    • 2005 ski nautique 206 SE
    RE: Correct Prop for 2000 Ski Nautique 196
    Best prop for that boat in my experience is the acme 422. I believe that is what they come with from the factory.
    Prior Boats:
    1999 Ski Nautique GT-40
    www.skiersofknoxville.org
    • dsums
      • Nov 2006
      • 37
      • Vancouver, BC, Canada
      Prop specs could change with engine specs. I have a 2001 196 with GT40 and I think it came with the original prop. just checked it and it is also an OJ Legend 4 blade. I can't tell details without removing prop nut though. There is a number stamped on it that may be the model # 92000. Don't know how helpful this is. Not a big deal to re and re the cotter pin and prop nut if you want.
      • M3Fan
        • 1034
        Re: RE: Correct Prop for 2000 Ski Nautique 196
        Agreed 100%. Smooth as could be, perfect for this hull from 0-WOT.
        2000 Ski Nautique GT-40
        2016 SN 200 H5
        www.Fifteenoff.com
        • Nautibouys
          • Dec 2008
          • 76
          RE: Re: RE: Correct Prop for 2000 Ski Nautique 196
          Size wise what I have would be fairly comparable. The Acme 422 is a 12.5 x 15.5, the OJ is a 13 x 16. Thanks for all the insight.
          • Nautibouys
            • Dec 2008
            • 76
            DSUMS just checked my prop and its marked OJ Legend and has the number F325 on it. Looking at their website, they have a model 324 and 326 still available, but no 325. Mine also has a 5 digit number like yours, but mine starts in 99xxx so I thought it could be the date stamp. Well, curiosity continues but at least I know size wise its comparable to what others are running. If you get a sec, check to see if you have a F325 or similar number on yours.
            • j2nh
              • Dec 2003
              • 628
              • Spread Eagle Wisconsin
              Curiosity got the better of me so I went out and checked the size on my 09 196.
              Acme 668 12.5" X 15.5" same as the 422 but the 668 has an additional .045 cup.
              2018 200 Team H6
              2009 196 Team ZR 409
              2005 196 Limited ZR 375
              2003 196 Limited Excalibur
              1999 196 Masters Edition
              1987 ProStar 190
              • east tx skier
                • 1561
                • Tyler, TX
                Another vote for the 422. Started with the stock OJ and as soon as I got that Acme on there, it just clicked for me.
                • Rick
                  • Mar 2004
                  • 1250
                  • San Diego, Ca
                  My 2000SN with Acme 422 towed practice for the 2004 Malibu open. Chris Parrish went into 41 off. I think that says it all
                  Nautiqueless in San Diego
                  • Nautibouys
                    • Dec 2008
                    • 76
                    Rick, where did you get the decal you put on the side? Looks good and seems to update the boat a little.
                    • NCH2oSki
                      • 1159
                      • Maryville, TN
                      Sorry about the incorrect info, I didnt know they had changed to the 668 on the new boats. Makes sense though to add some cup with the increase in HP on the newer engines.
                      The standard oj that came from the factory makes a great back up prop. I also tried OJ's version of the 422, dont remember the model number, and it was good, but the acme 422 is better.
                      Prior Boats:
                      • canuck
                        • Jan 2007
                        • 14
                        • Winnipeg, Canada
                        prop size
                        The correct prop (factory install) for 2002 196 is a 12.5 x 15.5. My prop is the original and it is also stamped with the nauitque logo.
                        • AirTool
                          • 4049
                          • Katy, Texas
                          Re: prop size
                          4 blade?
                          • canuck
                            • Jan 2007
                            • 14
                            • Winnipeg, Canada
                            RE: Re: prop size
                            Yes a four blade!
                            • sodbuster88
                              • Nov 2008
                              • 368
                              • Clayton, NC
                              RE: Re: prop size
                              Agreed best all around is ACME 422...it's factory on my '04 196. I've heard that the OJ 4-blade 13X16 will pull the rooster tail in a little closer to the boat. Can anyone confirm?
                              Peace..
