Underwater LED's on a 196
  • 2004196
    • Dec 2007
    • 162
    • University Place, WA
    • 2006 196LE
    LED's
    Lights are on, easy installation, about 3 hours including wiring. Hope to launch Sunay and will psot some night pics in the water.
    2004 196 LE Black/Grey
    330HP Excalibur Water Churner
    2002 Grey F150 Harley
    475+HP Supercharged Tire Burner
    • Miljack
      • Dec 2004
      • 1616
      • Charlotte, NC
      • '08 230 TE ZR6
      04 196, did you get a chance to get pics in the water? Lights look great! Did you mount the big one (center) to the drain plug? Or do 196's not have rear drain plugs?
      I'm sitting and staring at my lights right now trying to figure out where to mount them. I did find the pockets you described, thanks, that will help a bunch if I decide to mount outside the platform brackets.
      2008 230 TE-ZR6
      • Flipside
        • Feb 2009
        • 137
        • Portland, OR
        What type of lights are you guys using? This is exactly what I want to do with my '01-210, but I'm hesitant to drill holes in the hull, and not sure I'd get rid of my drain plug where you put the center one. I'm thinking of only using the two lights on the ends. Would be nice to see those night pics in the water!
        • j2nh
          • Dec 2003
          • 628
          • Spread Eagle Wisconsin
          196 does not have a drain plug in the transom.
          How they look in the water depends on water clarity. The river we ski on has a fair amount of turbidity so I went with the Abyss L800's that are very bright but also pricey.
          If you take your time and follow the instructions drilling through the hull is not that bad. Just make sure you have a plan for wiring and there are no obstructions on the inside of the hull.
          2018 200 Team H6
          2009 196 Team ZR 409
          2005 196 Limited ZR 375
          2003 196 Limited Excalibur
          1999 196 Masters Edition
          1987 ProStar 190
          • 2004196
            • Dec 2007
            • 162
            • 2006 196LE
            As j2nh said, there is no drain plug on the back. Since it is still pretty cold, the 5200 took several days to set up and completely cure so launching last weekend was not possible. I am going out of town for a week so decided to wait until I get back to relaunch boat which won't be until the weekend after next, 2/28, unless we get a nice day during week, then I will launch the 23rd or 24th. I will post pics as soon as it is back in. I've got a lot of friends here waiting to see these things in the water also.
            Drilling through the hull is no problem, just drill slow and steady. I measured from the center swim platform bots on the inside of the boat to the floor and simply transfered that measurement down from the center of the same bolts on the outside. I drew a line and then knew the thickness of the floor and how far up from the bottom to place the lights and run wires where I would be sure to have access to them on the inside.
            I may have said earlier but I located the wire harness for the keypad belly ballast tank switch back on the port side of the motor down where the exhaust goes under the rear floor before the gas tank. I just attached to that harness and operate them from the existing keypad switch. Same with the front docking lights, found that harness up under the dash so they operate with the starboard ballast switch.
            • 2004196
              • Dec 2007
              • 162
              • 2006 196LE
              #21
              OK, couldn't wait so launched boat, tired of skiing behind a MC anyway, time to "Nautique" it. Sorry, pics didn't turn out real well, may get some better ones later.
              • AirTool
                • 4049
                • Katy, Texas
                #22
                Re: Underwater LED's
                Originally posted by 2004196
                Picked up the Amphibians today. These things are BRIGHT! .... A6 lights measure 6" x 2" and A3's are 3.5" x 2"
                How many amps do each of those fixtures pull respectively?
                AirTool
                • 2004196
                  • Dec 2007
                  • 162
                  • 2006 196LE
                  #23
                  The A6 pull .5 amps and the A3s pull .35 amps each so I'm pulling 1.2 amps total for the three. Here's the web site with some info on the lights- http://www.oceanled.com/products/und...mphibians.html
                  • AirTool
                    • 4049
                    • Katy, Texas
                    #24
                    Re: Underwater LED's on a 196
                    Thanks....I had already been to the site....saw the website on the lens ...in your close up photo. I couldn't find the data though. The tech sheet was just a dimensional drawing.
                    Thanks again,
                    AirTool
                    • Grant_West
                      • 758
                      • Redwoodcity Ca
                      #25
                      Hey cool install. Thank's for sharing with us. You don't see alot of guys with ski boat's doing this kind of install or mod. IMO most of the Ski guy's don't even want a back seat in their boat LOL.
                      MikeSki and I are planning on doing a TEST. We are rounding up a few diffrent brands of underwater LED lights to Test. We are planning on taking pictures of the light pattern and how bright and how far the light pattern go's back ect also power draw/amp's.
                      This is the first I have seen of the lights you installed.
                      How much are the Amphibians
                      I see there is a 3, a 6,and a 12 LED light how much are each of them?
                      Thanks Grant
                      • CradGen2
                        • Aug 2020
                        • 1343
                        • Horseheads NY
                        #26
                        Where did you get them and what are some of the prices being paid for them?
                        • AirTool
                          • 4049
                          • Katy, Texas
                          #27
                          http://www.google.com/products?q=Amp...l=en&scoring=p
                          • saceone
                            • 650
                            • Montréal
                            #28
                            AMAZING!!
                            • 2004196
                              • Dec 2007
                              • 162
                              • 2006 196LE
                              #29
                              I ordered the lights from Emerald City Marine out of Seattle, WA. I paid $165 ea. for the A3's and $365 for the A6. I didn't price the A12. I did find them for a little less on the net but wanted to get them local in case of any problems, even if I paid a little more.
                              And Grant_West - I do not have a back seat in my boat, has never been used.
                              • Grant_West
                                • 758
                                • Redwoodcity Ca
                                #30
                                WOW; $700 for transome light's. It's good to see some one spending some money on some bling! Let me just say your lights look great. The Abyss and the bullet lines lights are around the same price as the A3's. Bullet lines has a NEW $300 LED that would go up against the A6
