What are these gauges?
  • jjgag60
    • Sep 2008
    • 165
    I am looking at a boat for sale and was wondering about the following gauges. There are two gauges just above where the steering wheel go that read empty and full. I am guessing they are for the ballast. But what about the gauges next to the driver's right leg ? I thought those were for the ballast. Any ideas what the gauges above the steering wheel are ? This is a 02 Super Air with the team stickers on it.
  • BSBell
    • Apr 2008
    • 159
    • Memphis, TN
    • 1996 Sport Nautique GT40 2005 SV211 TE 330 2009 SAN TE 409
    RE: What are these gauges?
    The one's next to your leg "should" be ballast guages. Maybe the owner added extra aftermarket ballast to it...
    • Mikeski
      • 2908
      • San Francisco, CA
      Can't really tell from the pix.
      As Bell said the gauges below the throttle should be the ballast gauges, should have labels Port, Belly, Starboard.
      Across the dash you could have, Oil Pressure, Battery Voltage, Temperature, Fuel Gauge, Depth gauge, Tach, Speedometer, Perfect Pass, clock, hourmeter (if not in the tach), etc.
      That would acccount for 4 fluid level gauges, but not 5.
      What happened to the steering wheel?
      • core-rider
        • Feb 2004
        • 1351
        • Huntsville, AL
        • 2003 Black SANTE
        If I remember correctly, the gauges down by your leg are fuel level, volts, and I think they used to put a clock in there, but it dosen't look like you have a clock in that photo. The two above the steering wheel are ballast gauges for the factory tanks in back. On the dash you should have water/air temp and water depth (either ends), oil pressure, engine water temp, tach, speedo, and PP.
        This was the typical configuration before 3 tank ballast systems and combo air/water temp and depth gauges in the mid-90's.
        Jason
        All black 2003 SANTE
        -- Southern Fried --
        • Laptom
          • Oct 2003
          • 876
          • Eindhoven, Netherlands
          Most likely this is a 2002 Team Edition with 3 ballast tanks...
          The gauges down at driver side leg are the 3 ballast tanks level gauges.
          On your dash at the outher side are the water/air temp and the depth meter gauges (digital with display). The three big gauges in the middle are Perfect Pass (also digital display), tach (with hour meter) and speed. Next to the big three and between the digital temp and depth meter would be the engine water temp and fuel level.
          The two at the steering wheel would be oil presure and batery voltage.
          As far as I can see you're missing the analog clock and a bezel aroung the small gauge at the steering wheel...
          • MNSuperAir
            • Sep 2005
            • 591
            • St Paul
            • 2016 SAN 210
            My 2001 SAN has the ballast on the panel next to your right leg and my buddies 2001 SAN has them like the pictures above. We always wondered why they were different. Did one of us buy a SS conversion, but we could never find any other differences even with the pump installs and wiring. CC must have had a day crew and an evening crew working different assembly process.
            2016 SAN 210
            2006 SANTE sold
            2001 SAN - sold
            1991 Sport Nautique - sold
            • jjgag60
              • Sep 2008
              • 165
              Gauges
              Thank you eveyone. The steering wheel was stolen from the boat for some unknown reason. If I end up buying the boat, I will have to purchase a new one or look for a used one.
              • Grant_West
                • 758
                • Redwoodcity Ca
                RE: Gauges
                JJGAG: Thoes gauges are to show you the amount of money in your bank account after you buy the boat.
                • saceone
                  • 650
                  • Montréal
                  RE: Gauges
                  god I miss that view!!!!!!
                  only 3 months left
