2000 Air Nautique towng weight
  • muz
    • Mar 2009
    • 1
    • Australia
    hey,
    would someone be able to tell me what a 2000 Air Nautique (direct drive) weigh's on trailer?
  • Quinner
    • 2246
    • Correct Crafts
    RE: 2000 Air Nautique towng weight
    Boat only dry weight is 2700lbs / 1215kg, trailer weight can vary, most are around 1,000lbs.
    Spec page from brochure: http://www.correctcraftfan.com/refer...ex.asp?page=30
    • Rick
      • Mar 2004
      • 1250
      • San Diego, Ca
      My 2000 SN Direct Drive without as tower is right at 4000lbs wet, with all the gear in it on a dual axle trailer I would think the tower would add around 300-500 lbs depending on the speakers lights and racks.
      Nautiqueless in San Diego
      • gotpwr
        • Aug 2004
        • 244
        • Louisville, KY
        • None
        Weighed mine back when it was new. 5,000lbs including a tandem axle trailer.
        2000 Air Nautique Powered by FORD <-- Former Boat
        • patoloco
          • 270
          • Indianapolis, IN
          I always estimated about 4500-4700 for my 99 air on a tandem with fuel and everything in it.
          3/4 ton pulls it through anything
          1/2 ton pulls it through most anything if it has towing package and good gear ratio
          mid size suv's will do the job for flat and shorter distances
          • AirTool
            • 4049
            • Katy, Texas
            My 06 206 weighs 4500 lbs with the single axle ramlin and a full tank of gas...nothing else.
            Tongue weigh is 450 lbs....**** heavy but it tracks like a dream.
            Weighed it all on a Cat scale.
            AirTool
            • gotpwr
              • Aug 2004
              • 244
              • Louisville, KY
              • None
              Re: RE: 2000 Air Nautique towng weight
              Originally posted by AirTool
              Tongue weigh is 450 lbs....darn heavy but it tracks like a dream.
              Same here. I couldn't understand why my Expedition was sagging so much, until I put it on a scale and found out the tongue weight was almost 500lbs.
              • patoloco
                • 270
                • Indianapolis, IN
                RE: Re: RE: 2000 Air Nautique towng weight
                A buddy of mine who owned a, light, 17ft runabout was helping me hookup my AN one day. He didn't line up the hitch quite right so he put his back under the bow and tried to lift the tongue onto the hitch like he does with his own boat......I heard a loud of yell of pain and some cussing about how heavy the d@mn thing was.
