99 Air Pod Panel replacement or upgrade
  • hornsfan
    • Feb 2009
    • 60
    Has anyone ever replaced the 2 panels on their "pod" These things are looking worn out and I'd like to update them somehow. If I cant get new ones then maybe sticker over the ones I currently have? Any ideas?
  • TRDon
    • Oct 2007
    • 722
    • MN
    RE: 99 Air Pod Panel replacement or upgrade
    This is a good question. I also want to do this to mine. The screw holes seem to always break no matter what boat I have seen them in.
    • Suicidal-Element
      • Dec 2008
      • 37
      • Citrus Heights, CA
      Buy some rigid Carbon Fiber Panels and put those in its place.
      • mcbridek
        • 241
        • Raleigh, NC, Lake Gaston NC
        • 06 Ski Nautique 196 SE (2010 - Current) 99 Sport Nautique / GT 40 / FCT (2005 - 2009)
        Burlwood
        They made the panels in burlwood - here is my 99.
        06 Ski Nautique 196 SE (2010)
        • hornsfan
          • Feb 2009
          • 60
          RE: Burlwood
          mcbridek, that looks nice. Is that what came with your boat or did you order that afterwards? Anyone know of a place that sells these?
          • hornsfan
            • Feb 2009
            • 60
            RE: Burlwood
            anyone know where I could order carbon fiber panels?
            • polkaking27
              • Jan 2005
              • 104
              I have been looking at changing out those panels on the boat that I get. I was also hoping to change them out to carbon fiber. Here is a link to a place that sells the carbon fiber panel blank. You would have to take them to a local machine shop to get cut out though. I believer the .025 would be sufficient for a purely cosmetic panel like these.
              http://www.dragonplate.com/
              if con is the opposite of pro, is congress the opposite of progress???
              • AuMDLST
                • Apr 2007
                • 870
                • Orlando, FL (Butler Chain)
                You can cut that with a razor knife - follow up with some fine grit sandpaper for the edge and you are good to go.
                2006 SANTE 210 (Pending Sale)
                2005 206 TE (Previous)
                • Suicidal-Element
                  • Dec 2008
                  • 37
                  Go to composite envisions on the web for the carbon rigid panels. They have all sorts of options and colors and their product is great quality!!!! You can usually cut carbon with either a knife by scoring it and breaking it off or by cutting it with a saw or something.
                  • hornsfan
                    • Feb 2009
                    • 60
                    could anyone that has access to their boat right away give me approximate dimensions as to the size of each of those panels? I'm thinking of ordering some carbon fiber panels as suicidal-element has suggested and I want to make sure i order enough to at least do the two panels.
                    If I had to guess (2) 12" x 12" should be enough.
                    • hornsfan
                      • Feb 2009
                      • 60
                      Polkaking, I think .025 would be too thin. According to this site, that measurement would not be that rigid
                      .015"/.4mm panel is very flexible and will bend around something as tight as a 2" diameter pipe.
                      .030"/.8mm panel will remain flexible and will bend around a 6" diameter pipe
                      .055"/1.4mm panel increases in rigidity and will bend around a 12" diameter pipe
                      .090"/2.3mm panel is where our panels become rigit. These panels remain quite stiff, however they will flex a little.
                      .165"/4.2mm panel will hardly flex at all
                      • polkaking27
                        • Jan 2005
                        • 104
                        You're absolutely right... Thanks for pointing that out. I didn't even look at those specs. Goes to show, I also thought you had to have a diamond plated blade to cut Carbon fiber, So this thread is teaching me all sorts of new things.
                        Post up some pics of your progress when you start, I'm sure I'm not the only one that would love to see 'em.
                        • Suicidal-Element
                          • Dec 2008
                          • 37
                          I like to play with Carbon Fiber. Here is a sample of the Hydrofoil CF boards that I make.
                          • Suicidal-Element
                            • Dec 2008
                            • 37
                            Back Side
                            • polkaking27
                              • Jan 2005
                              • 104
                              suicidal-
                              What kind of resin do you use when laying up your CF- epoxy, poly, vinylester?
                              Also, do you just do a regular wet layup or do you bag/bake them
