Best upgrade for 4 barrel 351? Or do prop?
  • Bimmerboyz
    • Feb 2009
    • 378
    • Herriman UT
    • 1978 Ski Nautique that I miss:-( 2003 SANTE
    I can't seem to locate them on that website.
    • rosconole
      • Sep 2008
      • 34
      • FL/SC/NC
      RE: Re: RE: Re: RE: Best upgrade for 4 barrel 351? Or do pro
      I drive past clearwater cylinder head about everyday...if anyone needs some heads done I can probably say you some $ on freight.
      • Bimmerboyz
        • Feb 2009
        • 378
        • Herriman UT
        Can you help me out with freight :mrgreen:
        J/K
        • 81nautique
          • Feb 2006
          • 257
          • Big Rock, Illinois
          • 2012 200 Sport 1956 Correct Craft Collegian Past boats 1955 Correct Craft Hurricane 81 Anniversary Nautique 1960 GlassCraft Ski Nautique #1
          Don't waste a dime on the stock heads, if you're already runninga 540 then the next upgrade would be the gt40p heads. You can pick a set up for under $500 if you look around. New cam can be found from Cam research, custom ski boat grind # 270 seems to be their popular choice and is what I run. If you don't want to change the cam then go roller rockers at 1.7 ratio and that will bump up the stock cam specs. If you replace the stock rockers with 1.6 rollers you are wasting $200. Go to CCfan and research 351 upgrades, you will find enough to make your head spin. Also agree with trbenj on the ignition, the electronic upgrades don't get you anything but good starting, no noticable performance improvements, I would go with a full electronic unit but it's not neccessary for you right now.
          • Bimmerboyz
            • Feb 2009
            • 378
            • Herriman UT
            SO I got my boat out of storage and it's in my garage now.
            My question is I have 2 props the one on it is a 542 13 x 11.5 1" and my spare is a 540 13 x 12 v 1"
            Which one is better?
            • 8122pbrainard
              • Jul 2007
              • 255
              #21
              It all depends on the use of the boat! 542 will give you a slightly better hole shot plus will be better keeping th rpm's at the sweet spot for boarding. The 540 on the other hand is great for skiing.
              • Yooper-Sully
                • Jul 2009
                • 6
                • Hancock,Michigan-The Yoop
                #22
                Definitely do a prop upgrade. Your better off setting the boat up for how you ride, if your putting ballast in an old boat a prop would fall under the Preventative Maintenance group.
                • horkn
                  • Aug 2007
                  • 270
                  • WI
                  #23
                  fwiw, I got a set of used gt40p heads from a 5.0 explorer, had them decked, springs checked, valves checked, brass freeze plugs, bolt holes drilled out to fit the 351, new valve seals, and a full top end marine gasket kit for $600.
                  That's bang for your buck.
                  • bobchris
                    Banned
                    • Apr 2006
                    • 359
                    #24
                    why waist time looking for heads and hoping the local guys knows what the **** he's doing, for that price you can get them all ready reworked and ready to bolt on for that same price and you don't have to wait on the machine shop either.
                    1.7 rockers and new heads and cam are the next step up the performance ladder, all for about a grand and that will get you in the 50mph+ club.
                    But if you don't want to listen to the people that have all ready done all this and know the gains, then your lose.
                    • horkn
                      • Aug 2007
                      • 270
                      • WI
                      #25
                      Well, I don't know if you saw it, but that price included the full top end Fel Pro gasket kit with both head gaskets and all the other top end gaskets specifically for my PCM motor. That alone was around 100 dollars If I recall correctly. Add the cost into the heads from tri state or elsewhere, along with shipping 2 heavy 50 lb + boxes to where you are if you get them from a non local place. Also, had my used heads not needed decking, the cost would have been even less. As I see it, my short amount of time I had to wait was well worth the $150-200 that heads from elsewhere would have run with gaskets and shipping. That amount of $$ is hardly a waste of my time, considering my original heads were totally fine.
                      I know the machine shop where I had my heads done, they do great work, and are very reputable. However, if you don't have such a good shop locally, then maybe tri state and more money is the route you should go. I will say that tri state has a great deal, I just got an even better one. Price a pair of gt40 (not even the better P heads) from DIM or so and you will be in shock.
                      • bobchris
                        Banned
                        • Apr 2006
                        • 359
                        #26
                        but what it lacks are spring travel for a high lift cam, undercut stems on the valves, and the unknow you get with used heads, so you can spend the same amount of money and have all new valves, seals, hardend seats, springs and retainers verus used springs and retainers that will have varing spring loads due to the age, old valves that do not have undercut steams with old seats that wil vary the push rod lengths enough that the pedastol will need shimed. So you got lucky and no valve were burnt, so for a big question mark by pulling parts off a used motor verses the know quality of something that is all ready done Tri-State is the safer cheaper route to go. Also the marine head gaskets are thicker too compared to automotive. So if you really want to get junk yard heads you should be looking for D0OE heads anyway and have them massaged and they'll out flow your GT40's all day long.
                        • pj
                          • Oct 2003
                          • 323
                          • Rochester, MN
                          • 1991 SN 1996 SN
                          #27
                          The gt40p's from Tri-State are remans. Hence the cheaper price than new from someplace like SkiDIM
                          Once you have tasted flight, you will forever walk the earth with your eyes turned skyward. For it is there you have been and there you will long to return. - Leonardo De Vinci
                          • horkn
                            • Aug 2007
                            • 270
                            • WI
                            #28
                            Valve stems were under cut, the springs are the same as the ones from tri state. The proper valve seals are in place as well. Tri state and the automotive machine shop I went to don't do anything differently. The shop I went to was very familiar with PCM and indmar marine motors. If they were not familiar with marine motors, I could see a reason for some trepidation.
                            I have the original set of heads from my boat, they are D80E heads that I am selling. I have no need to have them ported since the boat has a lot more power as it is with the edelbrock performer manifold and the gt40P heads.
                            The heads from tri state are used as well, probably old automotive heads just like I got and refurbished.
                            • horkn
                              • Aug 2007
                              • 270
                              • WI
                              #29
                              That and the gt40's that DIM sells are new old stock (NOS), and not as good of a performing head as the GT40P's.
                              • bobchris
                                Banned
                                • Apr 2006
                                • 359
                                #30
                                Valve stems were under cut, the springs are the same as the ones from tri state. The proper valve seals are in place as well. Tri state and the automotive machine shop I went to don't do anything differently. .
                                I doubt that. So what your telling me is your machine shop replaced all of the valves and all of the springs? about 300 in parts alone, factory heads do not have undercut stems for the valves? Do you even have a clue what I am talking about? doubt it based on your comments, Did your machine shop replace all of the valve springs? doubt that they did most shop rarely replace teh springs or valves unless they are broke or burnt or they are requested to be changed out, Tri state uses a better than stock spring to allow for a higher lift cam that you not going to get with stock springs. Same crap comes out of your mouth on CCF too. Your not the bright IMHO I would never let you around an engine.
