Made a mistake removing dash warning plate
  • aarond0083
    • Aug 2006
    • 686
    • Triangle, NC
    So I pulled all of the warning and danger stickers off the transom, tower, gear knob, and near each gas cap on my 210. Some might disagree with this practice but I've been boating long enough now that I don't need warning stickers.
    Once I finished with all those I decided to pull the one on the dash right of the stereo remote. Bad move as the sticker is on a hard plastic plate that is stuck on with a super strong glue and heat gun. It looks to me that the silver dash panel is damaged from the heat adhesive and there is no way to remove all the glue and plastic left behind for it to look new again.
    I have seen a few boats here with all the stickers and warning messages removed. That includes the dash decal as well as the two large ones near the throttle. Did those guys just replace the panels to get that look or was I just unlucky with the super strong heat glue.
    My options are clean it the best I can and deal with it, replace that silver panel piece with a new one, or just get another warning decal to cover up the mess. Replacing the panel is what i prefer but not sure how much one cost and how easy it is to remove and install.
    Maybe the N3 guys can chime in. Seems like they took apart and put back together a few Nautiques over in their shop.
    Previous Nautiques
    2012 210
    2009 210
    2007 210
    2004 210
  • wake4life6
    • Mar 2009
    • 218
    • Olympia, Washington
    I agree on removing the warning stickers but I'm not sure on that issue hope you figure it out cause your boat is sick!
    2006 210 SAN! TE
    • kevfran99
      • Sep 2008
      • 335
      • ATL
      • 08 210 SAN Team
      I wanted to do the same thing.......but was worried that something like this might happen! sorry! post up what you do to fix it!
      '08 SAN 210 Team Black w/Patriot red top stripe-Tow Biminis over the tower-4 under water transom lights-hot/cold shower-crest carpet-full throttle steering wheel-extra 6 channel JL amp-Pro 80's-WS420-fiberglass sub enclosure-led'd vents-Chromax Letters-and Tinted windshield for now......
      Tow Vehicle--05 GMC 2500 Crew Cab Short Bed 6.6L Duramax/Allison with a few mods
      -GO DAWGS!-
      • WIKD281
        • Mar 2005
        • 32
        I would fix it if I was closer to you! I would recommend checking with correct craft and seeing if you can get that panel without the warning stickers on it. If not, then I would go to your local auto body repair shop and see how much they would charge to fix the plastic areas where the stickers were and re-paint it. I have an 02 SANTE and have painted my Faria gagues to match my silver dash inserts and its not a big deal. Just need to find someone comfortable working with plastic and can do a good silver color match.
        Good luck with whatever you decide on doing.
        Harold.
        • SuperSquirt
          • Apr 2008
          • 534
          • Tennessee
          • 2008 SANTE 210
          Dont worry about it aaron, all you have to do it take a heat gun or hairdryer to it. Get it hot and it will peel off very easy, just like old stickers. You will also need to get some Goo Gone to clean up any residue left. Super easy to do. Mine peeled off perfectly and I will re-glue it when I sell it.
          • apexrig1
            • Dec 2008
            • 144
            You could find a peice of aluminum(ex Road signs) and cut it to fit and then polish it to look like crome. Glue it on or somthing like that.
            2008 SANTE 210 Orange Baby! Current
            2007 Gekko GTO22 Previous
            • aarond0083
              • Aug 2006
              • 686
              • Triangle, NC
              I have already put a heat gun to it with rubbing alcohol and goo gone. I'd love to use something stronger like paint thinnner but that will eat that plastic up. Also, the warning plate was applied with heat so some of the panel was melted with the glue when it was put on at the factory. I am going to try to get a new one from my dealer without the sticker. If by some chance I can't, I will take the panel off and figure out a way to cover it cleanly. Aluminum cut jut right may look really cool. I could engrave it and have my own custom dash plate.
              Previous Nautiques
              2012 210
              2009 210
              2007 210
              2004 210
              • awoollie
                • May 2007
                • 106
                • Katy, Texas
                • 2012 SANTE 210 Current 2009 SANTE 210 (sold) 2008 SANTE 220 (sold) 2004 SANTE 210 (sold)
                I did the same exact thing. Called the dealer and ordered a new one without the labels. I think it was somewhere around 50 bucks. Kinda expensive but it looks a lot better without the warning labels.
                • aarond0083
                  • Aug 2006
                  • 686
                  • Triangle, NC
                  awoollie, what model is your boat? and how easy is it to remove and replace the panel. I don't want to have to take half the dash apart.
                  Previous Nautiques
                  2012 210
                  2009 210
                  2007 210
                  2004 210
                  • awoollie
                    • May 2007
                    • 106
                    • Katy, Texas
                    I have an 08 220. Not sure about the new 210, but you can see how mine is attached.
                    • aarond0083
                      • Aug 2006
                      • 686
                      • Triangle, NC
                      $50 to replace the panel is my fix. So if you really want that sticker gone on your new Nautique just save time time and buy a new panel. I would also like to remove the two larger ones near the throttle but that panel is much more $$$ so those are staying.
                      Previous Nautiques
                      2012 210
                      2009 210
                      2007 210
                      2004 210
                      • AuMDLST
                        • Apr 2007
                        • 870
                        • Orlando, FL (Butler Chain)
                        If anyone knows differently I believe the information has to be in the boat at all times
                        (a) Capable of withstanding the combined
                        effects of exposure to water, oil,
                        salt spray, direct sunlight, heat, cold,
                        and wear expected in normal operation
                        of the boat, without loss of legibility;
                        and
                        (b) Resistant to efforts to remove or
                        alter the information without leaving
                        some obvious sign of such efforts.
                        http://edocket.access.gpo.gov/cfr_20...3cfr183.25.pdf
                        2006 SANTE 210 (Pending Sale)
                        2005 206 TE (Previous)
                        • SkiTower
                          • 2172
                          • Clayton, NC
                          and
                          I don't believe it's a legal requirement for the owner to have it on there, the requirement is for the company to provide the info (ex. mattress tags: not to be removed except by Consumer). But by removing the warning decals, you might be removing some sort of legal responsibility from CC. Also, if you resell it the next owner might run across a situation.
                          I'd love to hear a lawyer chime in, though.
                          2007 SV211 SE
                          Tow Vehicle 2019 Tundra
                          Dealer: www.Whitelake.com
                          • AuMDLST
                            • Apr 2007
                            • 870
                            I agree - Maybe someone can give an answer
                            I read it as it is required to be in there at all times - why else would they want it to leave signs of tampering.
                            Also as to capacity - how would anyone ever get busted for being over capacity if it is not in there?
                            • aarond0083
                              • Aug 2006
                              • 686
                              • Triangle, NC
                              Just for the record I left those signs you guys are now discussing in my boat. The only warnings I removed were related to the tower, carbon monoxide, gas fumes, and running props.
                              Previous Nautiques
                              2012 210
                              2009 210
                              2007 210
                              2004 210
