is their any way to cheat the weight limit sticker change it to 12 instead of 10 my buddy just got a 21 tomcat and its rated for 14 wtf I love nautiques will never change but on trips i wish i didn't have to be limited to 10 any body ever change the sticker?
Tags: None
RE: Weight limit sticker?
The sticker is for the Coast Guard. If you're on a lake, more than likely the coast guard isn't there.
However, I wouldn't exceed it to much. I'd still pay heed to the weight requirement...
Women are small not that hard to get twelve. our lakes always have cops on them checking us out. For safety guys are putting 2000 lbs of weight in their boat then having ten people on top of that I don't think its a big deal2006 210 SAN! TE
I do not believe it is just there for the Coast Guard. It is the maximum allowable for the craft at any time. Technically if you are running 1200 lbs of non factory ballast you cannot have a driver or anyone else in the boat. (using 1200 lbs for max riders and weight). You can get ticketed for exceeding either of the max allowable.2006 SANTE 210 (Pending Sale)
2005 206 TE (Previous)
Re: RE: Weight limit sticker?
Originally posted by AuMDLSTI do not believe it is just there for the Coast Guard. It is the maximum allowable for the craft at any time. Technically if you are running 1200 lbs of non factory ballast you cannot have a driver or anyone else in the boat. (using 1200 lbs for max riders and weight). You can get ticketed for exceeding either of the max allowable.'08 SAN 210 Team Black w/Patriot red top stripe-Tow Biminis over the tower-4 under water transom lights-hot/cold shower-crest carpet-full throttle steering wheel-extra 6 channel JL amp-Pro 80's-WS420-fiberglass sub enclosure-led'd vents-Chromax Letters-and Tinted windshield for now......
Tow Vehicle--05 GMC 2500 Crew Cab Short Bed 6.6L Duramax/Allison with a few mods
-GO DAWGS!-
RE: Re: RE: Weight limit sticker?
water pigs don't know how much ballast bags weigh. and you dont have to tell them the truth. i would not make a fake plate. sounds like a good way to get your boat taken away or something. have you ever had 10 people in your 210? it's not awesome.
The weight limit plates are a recommendation.the WakeSlayer
1968 Correct Craft Mustang
that being said, I wouldn't fake it. More than likely the local patrol would know the capacity of the various boats...
I've been pulled over with 14 in a 210. If you have life jackets and aren't doing anything "dangerous" then they can't do anything. The plate is a recommendation. It will give them a reason to mess with you a little more, but there is a limit on length when that number becomes a recommendation. I want to say it is 14 or 16' in Texas. Don't mess with the sticker. Just get educated on the laws in your area and that will be your best defense against the po po's
found this info number of people = vessel length (ft.) x vessel width (ft.) ÷ 152006 210 SAN! TE
Originally posted by wake4life6found this info number of people = vessel length (ft.) x vessel width (ft.) ÷ 15
