Manuevering trailer
  • nautique_dreamer
    • Jun 2008
    • 11
    Manuevering trailer
    I've got to make a 90 degree turn on a fairly narrow driveway to get the boat in and out of the garage (I need to store the boat there daily). Does anyone have any advice/experience about how to make that turn easily?
    Double axle trailer and no room for the truck to make the turn. I've ordered a pair of GoJak's for the rear axle of the trailer so at least I'm not fighting the 2 axles for making the turn. Has anyone used GoJak's? How about a motorized dolly? I don't have much of a slope, but I do have to make that helacious turn in very tight quarters. Any advice/thoughts are appreciated.
  • AirTool
    • 4049
    • Katy, Texas
    RE: Manuevering trailer
    http://www.airtug.com/?gclid=CNKc0Kv...SMeDQodXl1zVw#
    • chris196
      • Mar 2007
      • 223
      At the local Correct Craft dealer here, they use a small tractor with a ball on the front to move boats around.
      I was amazed at how they could maneuver the boats and also what a small tractor they were using. You could also mount a ball on the front of your truck. Same concept because you have the turning wheels where you need them.
      • CradGen2
        • Aug 2020
        • 1343
        • Horseheads NY
        The air tug is cool, but there are a couple electric ones that are cheaper. I can't find the sites from when I was going to get one. Upgraded the house instead.
        • SkiTower
          • 2172
          • Clayton, NC
          I don't mean this to sound condescending, but have you tried pushing it? If you don't have a slope, that's the way. Any kind of slope, you're out of luck. I have the same situation, but I definitely do have a hill and I need to go in nose first, therefore I winch it in (not recommended). This is a BIG reason my house is for sale!
          2007 SV211 SE
          Tow Vehicle 2019 Tundra
          Dealer: www.Whitelake.com
          • SkiTower
            • 2172
            • Clayton, NC
            Re: RE: Manuevering trailer
            And I've seen the cheaper ones, but there're still the high side of $1000.
            2007 SV211 SE
            • SkiTower
              • 2172
              • Clayton, NC
              RE: Re: RE: Manuevering trailer
              here are a few products I found with a quick search.
              http://www.powercaster.com/
              http://www.djproducts.com/products/trailer-mover.html
              http://www.powermoverinc.net/htmls/pmaccarts.html
              http://www.trailertugpro.com/
              2007 SV211 SE
              • Dallas
                • Mar 2009
                • 30
                • Tennessee
                tractor supply company or similar rural supply shops have non powered "tugs" more like a hand truck with a trailor ball mounted on it that are arround $100.
                Here are some other sites of interest
                http://www.powerwheel-usa.com/products/powrhitch.htm
                http://www.ehow.com/how_4728593_buil...lor-dolly.html
                Also try ebay. This is similar to the one I use; my dolly is a bit beefier.
                http://cgi.ebay.com/600lb-Dolly-w-12...1%7C240%3A1318
                Good luck
                • Nautiquehunter
                  • Jun 2008
                  • 2080
                  I store 3 boats in my barn for the winter to make max room I need to put them very close .There is not enough room to maneuver a tow vehicle inside so I use a small tractor with a ball on the front works great.
                  You can find them used very cheep.
                  • Hlymons
                    • 223
                    • Roseville, Ca.
                    I have a similar issue in that I have a tandem garage and have to negotiate cabinets and a refrigerator to get the boat to the back spot. What I did was to sink a round pvc sleeve into the ground and I attach a 12 volt winch and pull the boat back.
                    • skiinxs
                      • 374
                      • St. Louis
                      • 2019 Ski Nautique 6.2 arriving soon
                      What do you tow with? I insatlled a front hitch on my suburban for this type of activity. Several manufacturers make front hitches for a lot of different vehicles. You can do a lot of tight manuvering this way.
                      Dave
                      16 other Ski Nautiques
                      3 MasterCrafts
                      18 Ski Supreme's
                      1 SlickCraft Squirt Boat
                      • DavidF
                        • Sep 2004
                        • 611
                        • Austin, TX
                        I always wondered what the ball on the front of trucks was used for, now I know. Yes, I would suggest a riding lawn mower (tractor) with a ball mounted. Bonus is that it serves two purposes - Boat trailer maneuvering and lawn mowing. What else to you need to convince the significant other.
                        • ffmedic74
                          • 835
                          • Lexington, KY
                          I would buy an old riding mower. They worked well for my old garage that was on a 90 degree angle.
                          • harddock
                            • Apr 2008
                            • 292
                            • toontown E-9
                            I've used gojacks and you would really want one on each wheel for them to work. Sad to say but that 90 dgree turn would be easier with a single axle. The front hitch maybe the eassiest (cheapest) solution.
                            • mf01
                              • Jun 2005
                              • 515
                              • Austin, TX
                              I store my boat in a tandem garage. I'm able to pull and maneuver the boat with this: http://www.harborfreight.com/cpi/cta...emnumber=37510
                              Side note, I have a single axle trailer.
                              Previous:
                              2011 Super Air Nautique 210
                              1994 Sport Nautique
