I have just bought a Ski Nautique for the first time about a month ago. It is a 1995 Ski Nautique with the GT40. I recently added the Fly High Pylon and noticed the tower moving from side to side (not front to back) with heavier wake boarders. I went ahead and tightened the (4) nuts that attach the pylon to the boat. This reduced the movement, but did not eliminate it. The tower still moved to the left and right about 1 inch in each direction at the top of the 7' pole with heavier boarders. It moves enough you can actually see the bottom pylon attached to the boat moving too. Is there reason to be concerned with this?
RE: Loose Pylon with Fly High
Make sure it is not loose at the floor?2008 Super Air 210 Team
2004 AIR 206 Team
1997 Ski Nautique 196
1993 Ski Nautique SNOB
I do not believe it is loose at the floor. I went below the floor where there are (2) U-Bolts with what looks like 1/2-13 threads and lock nuts. I have the nuts all tightened to as much as I could with a 1/2" Ratchet and Socket. But it still appears the pylon in the boat will move side to side with the extended pylon attached to it.
