Gas Guage problem
  • cotton
    • Feb 2009
    • 225
    • 2013 200 OB TEAM (ordered) 2011 200 OB (Sold) 2009 206 TEAM (Sold)
    Gas Guage problem
    I'm looking for some friendly advice. My 2009 SN206 Team gas gauge has never been very accurate but is now totally unreliable. The tank is 29 gallons and while showing a 1/4 would only hold 7 gallons. Then after filling it totally the gauge registered empty, then moved to 1/2 and generally hovered around a 1/4.
    Anyone have a similar experience and if so, was it the gauge, sending unit, or other defect(s)?
    Thanks in advance!
  • sjames
    • May 2009
    • 219
    • California
    RE: Gas Guage problem
    2006 SANTE 220
    Mine was reading low when I turned on the blower, and not very accurate at others times. The shop told me the ground was not secure on the main harness. They did not show me where but you might just check that the connections are tight first?
    Do the right thing.......
    • 2gofaster
      • 671
      If it's a team or limited then it's getting it's power and signal feed via the canbus interface to the Gateway box at the stern of the boat. The gateway box gets the signal from the float sensor in the tank. Those boats also have notirously inadequate grounds and power wires in the harness. So it could be a faulty gauge or a bad ground. I've had gauges go bad. They are about $70 and take about 3 minutes to replace.
      Shane Hill
      2014 Team 200OB
      67 '13 Prophecy
      • cotton
        • Feb 2009
        • 225
        Thanks guys!
