Larger swim platform
  • dfeltham
    • Aug 2009
    • 1
    Is is possible to use a swim platform from the newer boats on my 1998 Air Nautique? I like the new ones for the extra size and also being composite with rubber cover.
  • Lvnspeed
    • Aug 2008
    • 393
    • Smith Lake AL
    I know this isnt exactly a good compairson but I took a composite platform off a 2003 196 and installed it on a 2005 206 that had a teak platform. All I had to do is loosen the screws for the brackets on the platform slide it into place then tighten the screws back again the brackets were about 1/8-1/4" off. I too love the composite platforms. I hope this helps.
    2003 226 LE
    • MHayes
      • Aug 2004
      • 830
      • Roswell, GA
      The key would be if the curvature of the transom on your 98 is the same as the platform you plan on using. Lvnspeed's example of switching platforms between a 2003 196 and a 2005 206 is easy due to the fact that the transoms are very similar in shape.
      2001 Air Nautique
      • Chexi
        • Apr 2025
        • 2119
        • Austin
        • 2000 SAN
        Sorry, but Teak rules.
        Now
        2000 SAN
        Previously
        1999 Air Nautique
        1996 Tige Pre-2000
        • swooddc
          • Oct 2006
          • 147
          • Gardendale, AL
          I got lvnspeeds 03 206 platform, it fit perfect on my 97 closed bow ski. There was a significant size difference but the curvature was identical as well as width. Thanks lvn, we love it.
