SANTE ballast vents
  • Shooter
    • Apr 2025
    • 264
    • Orange County California
    • 2003 SANTE 210
    SANTE ballast vents
    I have noticed my ballast will sometimes fill and empty when the pumps are not on. I have been closing the intake valves after the tanks are filled to keep the water in. I keep them closed during and after empting to keep them empty. I’m confused how the three ballast vent switches located under the helm work. Do these only need to be open when empting the tanks?
  • core-rider
    • Feb 2004
    • 1351
    • Huntsville, AL
    • 2003 Black SANTE
    RE: SANTE ballast vents
    Those are not ballast vents, they are shut off valves for filling. The original valves have a service bullitin because of leaking that would force fill the tanks if the ball valves were open. If you are closing the ball valves on the seacock then those other valves can be left open or even removed if you so choose.
    Do you have any sacs added besides the factory tanks. I've never had issues with the factory tanks draining, but sacs on top of the tanks take a little work to fix.
    Jason
    All black 2003 SANTE
    -- Southern Fried --
    • Shooter
      • Apr 2025
      • 264
      • 2003 SANTE 210
      Core-rider... No sacs yet, but I plan on adding them soon. I found your post regarding your install and plan on doing the same thing with some slight modifications. You still happy with your set up?
      You said the original valves have a service bulletin. Does that mean they need to be replaced to work correctly? I purchased the boat used and they are probably the original valves. I have a 03.
      • core-rider
        • Feb 2004
        • 1351
        • Huntsville, AL
        • 2003 Black SANTE
        Yes, I haven't had any real issues with that setup. I still would like to tweak a thing or two and eventually want to replace the pumps with Jabscos, but the system works well as is.
        Here is the service bulletin... http://www.planetnautique.com/Correc...Manuals/sb.pdf I just got the parts sent to me and did the work myself. Not sure if the service bulletin will still be good but it's worth a try.
        Jason
        • Shooter
          • Apr 2025
          • 264
          • 2003 SANTE 210
          Nautique Warranty Service replied quickly and said it is still covered, but I need to bring it in to the dealer. Thanks Core.
          • steve-o
            • Jul 2009
            • 231
            What if you don't have a dealer nearby?
            • core-rider
              • Feb 2004
              • 1351
              • Huntsville, AL
              • 2003 Black SANTE
              Re: RE: SANTE ballast vents
              Try to call your "local" dealer or a dealer with good history and see if they will work with you and just take care of getting you the parts. Then you can install them. It's really not hard to do. If the dealer you call won't do that then try calling CC and tell them your situation. Maybe they will help.
              Jason
