transmission slipping??
  • KB
    • Apr 2008
    • 10
    Not sure how to diagnose exactly what is wrong here....
    on ym 89 Sport, from time to time there seems to be a bit of a "jump" coming out of the hole, like the prop doesn't quite catch and start pushing the boat the exact moment the throttle is engaged. Almost like it hesitates a bit.
    Also, I noticed last week that every once in a while it felt like the engine was working pretty hard at low speeds. Jsut didn't quite sound right.
    I've got a great repair guy, but it's a bit of a pain totake it to him, so if it's something simple or nothing at all, I'd rather not make the drive.
    Any ideas? Hopefully I described it well enough.
  • WakeSlayer
    • Sep 2005
    • 2069
    • Silver Creek, MN
    • 1968 Mustang
    RE: transmission slipping??
    Change the fluid recently? Or check it? Fluid should be dexron III if it is pink, if it clear, I believe 20W. Double check your manual for this. My 90 SN had 20W in it.
    for what it is worth, if Dexron, I have read to NOT use the high mileage stuff.
    the WakeSlayer
    1968 Correct Craft Mustang
