Don't know if I need to worry or not.
The past two times I have gone out I had a little hick-up with the throttle.
After a rider goes down I would slow the boat to idle, turn and then throttle up to return to the rider. When I throttle back up the motor would kinda bog down for a sec. the first time it did it I almost didn't notice it. Today it did it agian and the see dealer light flashed and then went away when I pulled the throttle back to idle.
From then on I tried to make it do this and it wouldn't . Like I said, it has done this once the past two times I have gone out. I don't know what could be causing this. The only thing I could think of is the fuel filter. I was not planning on changing it till this winter. Think it could cause this to happen?
Justin
Justin
