What thread sealant have you all used on your bag fittings? Thanks
RE: Ballast bag install question
I got it from Home Depot. Fly High said not to use the primer/glue PVC combo (probably because the primer actually softens the plastic and could ruin your threads. It was the all purpose glue). Ill see if I can find it and get a part # off of it.
I didn't use any.2016 SAN 210
2006 SANTE sold
2001 SAN - sold
1991 Sport Nautique - sold
Just the threads on the bags and hose clamps on the hoses here.the WakeSlayer
1968 Correct Craft Mustang
No. But you could get rubber caps at Home Depot for them. Not a bad idea. There is other semi shapr stuff in there, too. Never had a problem however.
My bags push on my dividers pretty hard too, but my motor is right there to stop them.the WakeSlayer
My bags have never had a problem and I never covered the bolts. I think the bag hits the angle in the stern on the 2001 SAN. I did have to cut a bunch of bolts and screws in the ski locker though.2016 SAN 210
2006 SANTE sold
2001 SAN - sold
Re: RE: Ballast bag install question
Originally posted by MNSuperAirI did have to cut a bunch of bolts and screws in the ski locker though.
Re: RE: Re: RE: Ballast bag install question
Originally posted by sethI throw orange CGA vests between the bag and the screws. That way they are in the boat and out of the way!
Do the 750's fit with the stock tanks in there? I cut mine out the day I got the boat home.the WakeSlayer
Originally posted by WakeSlayerDo the 750's fit with the stock tanks in there? I cut mine out the day I got the boat home.
RE: Re: RE: Re: RE: Ballast bag install question
My mistake. I was thinking lockers, as in the rear compartments. Not the center locker. I just leave a bag full in there and opted to not annex that to my auto system. I do not tow, generally, and it also helps offset the additional weight in the back from the big pig of a motor.the WakeSlayer
