Planned ballast system for my DD
  • snowboardcorey
    • Dec 2007
    • 105
    • Minneapolis, MN
    • Past: 1968 Ski Tique
    #31
    The Jabsco pumps are the best, that being said if money is an issue you can also check out Simer 12V pumps (I got mine at Fleet Farm) These are not really Marine pumps so I wouldnt mount them in the bilge area but if you are putting them in the trunk or up under the observers seat I don't think there should be any issues. The Simer pumps are usually less than 100 bucks.
    The problems with the Simer pumps are finding new impellars if you burn them out, obviously you can't roll into your local CC dealer and get them.
    Sold my boat to buy a house, the house is much less fun.
      • Feb 2025
      #32
      I'm considering mounting my bow pump between the engine compartment and the ski locker somehow.
      • ers906
        • Feb 2010
        • 921
        • Phoenix AZ
        #33
        Ian at onlyinboards got me a smoking deal on Jabsco pumps
        Call up Ian at only inboards. He got me a smoking deal on the pumps etc, plus there is a PN discount. ither are being delivered on friday so I will be updating on the progress of the ballast project
        Eric, Phoenix AZ
        G23 550 hp (finally here)
        2002 Super Air
        • mhaaland
          • Jul 2007
          • 217
          • Des Moines, IA
          • 98' Air Nautique
          #34
          I need some opinions on my ballast system.
          1. I'm using the hard tanks but the inlet fitting is only 1/2". So I'm planning on one of two things.
          a. cut off the thread insert and bore out the existing hole so my 1-1/2" to 1" thread insert will fit and epoxy it in?
          b. cap off the original inlet and drill and hole next to it and epoxy my 1-1/2" to 1" insert?
          See attached pictures below.
          2. I got a sheet of stamped aluminum from work to mount my ballast puppies on and one side of it is stamped. I'm mounting this in my rear locker so it will be visible. Do I.
          a. Let the aluminum sheet show?
          b. cover it with carpet?
          See attached picture below.
          FCT 2 by NDT
          Teak Platform Restoration
          Re-Carpet Trailer
          Oxidation Removal
          Re-Decal Boat
          Interior Restoration
            • Feb 2025
            #35
            Matt, I think you are going to need more rear - side weight to surf (based on my attempts to date on my 99 Air). With 2x 400 V-drive sacs on the surf side, the wake was just barely surfable.
