Air Nautique Draft
  • jaybird
    • Oct 2008
    • 516
    • North Alabama Lake Weiss
    Air Nautique Draft
    Does the Air Nautique V-Drive draft the most water when at rest? All other variables such as total load being the same or can it draft more under power, if so is any data published with known variations due to speed?
    I have debated this with friends for quite some time. If you have any links to published information and/or data please post it here. I know everyone has an opinion but for the sake of discussing the facts and not starting another ongoing endless debate, please limit responses to known data not personal opinions or hearsay. Thanks!
    2012 Team Ski Nautique ZR409
    2011 Sport Nautique 200
    2008 SANT 230
    2003 Air Nautique 226
    1988 Martinique
    1979 Nautique
    1978 Tique
    1976 Tique (First New Boat)
  • AuMDLST
    • Apr 2007
    • 870
    • Orlando, FL (Butler Chain)
    More Draft???
    This may draft more - but I think you are looking for info on just Nautiques? Would that be a comparison of v-drive to DD??
    2006 SANTE 210 (Pending Sale)
    2005 206 TE (Previous)
    • gspotrider
      • Nov 2009
      • 12
      RE: More Draft???
      Nimitz class aircraft carrier has a draft of 37-41ft. It has four propellers each 25ft. in diameter and weighing in at 30 tons. I bet it cant do a power turn.
      • hondaprlud
        • Jul 2008
        • 568
        • OH-IO
        RE: More Draft???
        since AuMDLST started it. . .
        I don't think either drafts, cans or bottles. I guess maybe one of those small kegerators, but I've never seen it done Yellow_Flash_Colorz:
        19 SANTE 210
        08 SANTE 210 ZR6
        08 SANTE 230 ZR6
        88 Baja Ski Sport- First boat
        • WakeSlayer
          • Sep 2005
          • 2069
          • Silver Creek, MN
          • 1968 Mustang
          Re: RE: More Draft???
          I think you would be surprised ! But it takes like 2 miles.
          I don't have any documentation or published test reports on SAN draft. Nor Miller, Michelob, or otherwise.
          However. my SAN drafts more sitting, than unweighted runnning at any significant speed. Heavily weighted surfing it drags really low.
          If that is not helpful, I recommend we go back to aircraft carriers and beer.
          the WakeSlayer
          1968 Correct Craft Mustang
          • AuMDLST
            • Apr 2007
            • 870
            RE: Re: RE: More Draft???
            I'll look for some numbers - I used to have measurements from a 1994 SNOB and a 05 206 TE. I do know the current 210 is more than both previous while sitting as well as all three draft less
            while underway on plane.
            • Rick
              • Mar 2004
              • 1250
              • San Diego, Ca
              The Nimitz is 30 tons. I think you missed a few zeros. The average tractor trailer rig is 30 tons and I think it's only 60" long. It may weigh more full of Draft Miller or Budweiser
              Nautiqueless in San Diego
              • jaybird
                • Oct 2008
                • 516
                Re: RE: Re: RE: More Draft???
                Rick,
                I am no expert but I think he said the propellers were 30 Tons
                2008 SANT 230
                1988 Martinique
                1979 Nautique
                1978 Tique
                • AirTool
                  • 4049
                  • Katy, Texas
                  RE: Re: RE: Re: RE: More Draft???
                  Comments to three topics
                  1. I think a vee drive would draft less at any speed....unless there is some contraption or feature on the hull to pull it down. Related to direct drives, see my post here.
                  2. Nimitz displacement is 103,000 tons fully loaded. I believe it can turn sharper than 2 miles.
                  3. No comment. I know nothing about or drink any beer I see TV commercials for. Nothing wrong with advertising....those just aren't good beers.
                  • gspotrider
                    • Nov 2009
                    • 12
                    yes each prop is 30 tons. It has a length of 1,092ft. which is just over the length limit on my lake of 21ft.
                    • Rick
                      • Mar 2004
                      • 1250
                      • San Diego, Ca
                      My Bad... Must be to much of the other draft.
                      • saceone
                        • 650
                        • Montréal
                        thread of the year!!!5* !!
                        • bobchris
                          Banned
                          • Apr 2006
                          • 359
                          almost every boat will draft slightly more before coming to plane when you are starting from a stand still the more gas the more draft you'll see.
                          • srock
                            • Oct 2008
                            • 1068
                            What, if their comming back with the draft I hope I end up on that Nimitz because that Nautique it too small and the drinking age should be changed to 18. No matter how many first class seamen are drafted on board there are too many factors to compare drafts without more parameters on your arguement. On either boat, put all the weight in the back and run slow you will probably draw more water due to the angle of the boat.
                            • AirTool
                              • 4049
                              • Katy, Texas
                              At the houston boat show last week, the Epic salesman told me their hull is designed to pull down with speed.
