Upgrade wire to fuse box 2001 SAN
  • vr6mole
    • Feb 2009
    • 106
    • Carnegie, PA
    I remember someone posted something about this because their Perfect Pass was shutting off due to a voltage drop but couldn't seem to find the thread.
    I noticed that the power/ground for the fuse box under the dash is only about 16 AWG. I was planning upgrading this to 8AWG for better voltage to the dash and other important accessories. I noticed before when I would turn on the blower or other items then the voltage on the dash would drop pretty significantly.
    1. I tried to trace the red wire with the black tracer back to the engine and can't seem to find where it ends up. I imagine it is on one of those large fuses next to the ECU 60/30/5, any idea which one?
    2. Could I just run the 8AWG wire with a 60 amp fuse right off the battery and power the fuse box? Basically treating it as an extra amp on the boat.
    2001 SAN
  • KPNautique
    • Sep 2005
    • 88
    • FL
    I believe your fuse box currently gets its power directly from the Batt. Is there a smaller gauge wire connected to the positive baterry terminal?
    I powered my 02 Air fuse box from the Batt selector switch that I added with #8. This has worked well.
    • vr6mole
      • Feb 2009
      • 106
      • Carnegie, PA
      no, its not coming from the battery. It should be fused which is why i think it comes from the area next to the ECU.
      What did you do with the exiting wire when you upgraded to 8#? Notice any voltage drop when using accessories such as the blower?
      2001 SAN
      • KPNautique
        • Sep 2005
        • 88
        • FL
        It was years ago that I did this. The reason I changed it was exactly what you are talking about.
        I installed two batterries that are connected to a (1 or 2 or both) battery switch under the dash. The switch feeds the engine (starter and alternator) and the fuse boxes directly.
        I only installed a 40 amp fuse to the box as my amps and balast pumps are connected to a separate fuse block.
        I no longer get a voltage drop.
        • KPNautique
          • Sep 2005
          • 88
          • FL
          Don't forget to upgrade the neg. wire also. That is just as important.
          • WakeSlayer
            • Sep 2005
            • 2069
            • Silver Creek, MN
            • 1968 Mustang
            This is on my Spring project list also. My plan is to just tag an additional powers and grounds off of my distribution blocks for my amps. I have 2ga. wire up to those. And will jump from the blocks with 8ga.
            the WakeSlayer
            1968 Correct Craft Mustang
            • vr6mole
              • Feb 2009
              • 106
              • Carnegie, PA
              What did you do/plant to do with the existing power and ground wire?
              Did you leave them in place on the fuse box? (shouldn't hurt anything)
              Or we may use that to as a source of constant power for something else.
              2001 SAN
