Hello,
I have a 94 Sport Nautique used for wakeboarding. How do you weigh your 93-97 Sport Nautique?
I am using about 700lbs hidden behind the rear seats. 250lbs under the bow. 500lb water sac in the ski locker and 300lbs hidden behind the sidewall near the drivers and passenger seats.
So about 1750lbs of weight.
The wake is great at 21mph+. It washes up pretty good at 19mph. But generally we ride at 22+mph and it is top notch.
The one issue I have is porposing or bouncing at anything above 31mph when cruising.
Is there anyway to fix this porposing? I don't want to add any more weight to the front as this seems to be the common advice on the boards. I am already well over the amount of weight that I want to run. (Please don't turn this into a water vs lead weight discussion - I know the risks of running lead).
Kevin
Kevin
