I'm looking into trailer/boat lift issues for a 2000 Super Air Nautique and need to know the following;
1) What is the lowest point on the boat as it sits in the water; fins, prop, rudder?
2) I realize the draft is 28", but I want to know the minimum draft I would need to run the motor and have it draw water with the water pump. So basically, I need to know the distance between the lowest point of the boat and the water pickup on the bottom of the hull.
