Just wondering if i have to remove the fuel tank to get the hard ballast tanks out of my rear locker? If now does anyone know of an easy way to remove the hard tanks.
Unless you want to cut them out, you'll need to remove the fuel tank. For me, one of the hardest things to get loose were the fuel filler line and vent lines! Other than that, not too bad. You can remove the brackets and slide the fuel tank forward enough to remove the ballast tanks, I think. Been a few years since I've removed mine.2008 230 TE-ZR6
