Best advise for installing NEW style raised letter graphics.
  • keith
    • Jan 2007
    • 198
    I will be installing the new style raised letter "AIR NAUTIQUE" graphics (part # 80075, nautiqueparts.com). They are not cheap so the first time has to be done right. I have installed many flat style vinyl graphics where you can use a solution of windex or soapy water and a squeegy but I do think that will work for these bubble letters.
    Any suggestions from PN members with experience installing these decals?
    Thanks,
    Keith
  • KenG
    • Oct 2006
    • 29
    • Minnesota
    • 1991 Ski Nautique 1997 Ski NautiqueW/ GT 40 2006 206
    Thanks,
    Keith
    There should be no reason to use a water solution, water soap solutions are to eliminate small bubbles that will not show with the raised lettering. Just be sure the surface is clean and the graphic is positioned exactly where you want it. peel and stick.
    2006 Ski Nautique 206
    1997 Ski Nautique CB
    1991 Ski Nautique
    • Adrenaline1
      • Jan 2018
      • 199
      • MI
      • 2019 GS22
      Any new advice on this topic? Anyone know how Nautique installs the thick side logos in perfect position? I may need to replace an entire "super air nautique" logo on the side of our boat. How can you get it all positioned perfectly? Can you use the spray water solution to get them to move around easily, then they still stick when it dries like the old regular sticker style decals do?
      • swatguy
        • 1631
        • Midwest/ Northern IL
        • 2008 SANTE 210
        I did mine this way. Didn’t use any solution. I did the entire super air antique down my side.
        I used painters tape and taped just above the old graphic and just under following the entire words down the boat. This gave me a straight line to follow right down the entire length of the boat. While the decal comes in a long strip I cut about 4-5 letter intervals.
