Single axle vs tandem axle trailer
  • Bimmerboyz
    • Feb 2009
    • 378
    • Herriman UT
    • 1978 Ski Nautique that I miss:-( 2003 SANTE
    I currently own a 1978 Ski Nautique with a single axle trailer. I am looking for a SAN, everyone that I seem to like has a single axle trailer, which is kind of a deal killer.
    My question is should it be a deal killer? If so where can I find a tandem axle trailer for a SAN?
    I lost a hub on my boat trailer last summer and it ended up costing me around $600.00. This is why I ask.
    Mainly because it could have ruined my trip, luckily I was driving home from the lake not vise versa.
  • LT206
    • Mar 2006
    • 262
    • Huntsville, AL
    I don't have a SAN, but I like my single axle trailer on my 206, it makes it much easier to maneuver it by hand in the garage. You just have to be diligent about hub maintenance - I check them everytime I start out on a trip and add a couple shots of grease and I've never had a problem. I totally rebuild them about every three seasons.
    • bubba
      • Jan 2010
      • 79
      • Minnesota, USA
      • Current: 2008 Ski Nautique 206 Previous: 1984 Ski Nuatique 2001 Long time ago: Glastron/Carlson DV16, 115 Johnson
      I am wondering how far you trailer. I prefer a single axle since I only put about twenty miles on a year and as mentioned previously I like the manual maneuverabilty of a single axle as oposed to a dual.
      • Rick
        • Mar 2004
        • 1250
        • San Diego, Ca
        Distance is key
        I think a single axle trailer would be fine for trips under an hour each way. If you are going for a long haul I like the security of spreading the weight between 4 tires rather than 2. Having said that I trailed a 66 Barracuda 6 hours each way for 4 years without a problem. Although, the boat and trailer was only 3000lbs total.
        Nautiqueless in San Diego
        • mcbridek
          • 241
          • Raleigh, NC, Lake Gaston NC
          • 06 Ski Nautique 196 SE (2010 - Current) 99 Sport Nautique / GT 40 / FCT (2005 - 2009)
          I like the single axle - mine just came from Dallas to Raleigh NC 1200 miles. Last week we went do to Ocheeheelee in WPB FL - 800 miles each way. Once I start driving a longer distance, after 30 to 45 minutes I stop and touch the hub to see if it is hot (vs warm). If the bearing is starting to go - it will be very hot. Grease a few times each season. I never have a problem (only once, will never have a problem again)
          06 Ski Nautique 196 SE (2010)
          • hourglass
            • Mar 2010
            • 248
            • lower bama
            • 2005 SANTE
            having had both with 21' v drives i like the tandem. i do alot of towing. i did not have any issues with my single though. just not as smooth of a ride. you could buy my boat with a tandem trailer.
            • ffmedic74
              • 835
              • Lexington, KY
              If you have a dual axle trailer and a bearing goes out, you will still be on the side of the road, unless you remove both wheels from the each side of the same axle.
              • WakeSlayer
                • Sep 2005
                • 2069
                • Silver Creek, MN
                • 1968 Mustang
                Bimmer,
                Seriously, dude. Buy a boat and be done with it.
                the WakeSlayer
                1968 Correct Craft Mustang
                • BrennanK
                  • Feb 2009
                  • 348
                  • Hopkins, MN
                  Originally posted by WakeSlayer View Post
                  Bimmer,
                  Hahah.
                  +1
                  1997 Ski Nautique
                  • Bimmerboyz
                    • Feb 2009
                    • 378
                    • Herriman UT
                    I have a boat. I thought this was a good question prior to my purchasing of a new (to me) boat. My bad if this thread caused some sand between the curtains.
                    I trailer about 65 miles to the lake and back. I also trailer 400 miles one way twice a year. I do enjoy the single axle for maneuvering my current boat into the garage.
                    Tandem axle owners can you maneuver your boat into a garage with just one person?
                    • TRO
                      • Mar 2009
                      • 410
                      • Houston, TX
                      i have a tandem trailer on my 230 and there is no way i can even move the thing by myself, much less maneuver. i think the single makes it easier to maneuver, but if you can afford the dual, i think it is safer for sure.
                      • Bimmerboyz
                        • Feb 2009
                        • 378
                        • Herriman UT
                        230 is a big boat. I wonder what the weight difference is between a 210 220 and 230.
                        • SkiTower
                          • 2172
                          • Clayton, NC
                          I think it depends on what you mean by a SAN. A 210 with a single might work, can't imagine a 220 or 230 on a single axle. If you're having to maneuver in a garage, a single is a BIG plus. But I would want the trip safety of the dual first. 196 or 206 is good on a single, anything else and I'd start to worry a little.
                          2007 SV211 SE
                          Tow Vehicle 2019 Tundra
                          Dealer: www.Whitelake.com
                          • hondaprlud
                            • Jul 2008
                            • 568
                            • OH-IO
                            Bimmer- I'm assuming you're looking to buy a 210. Your question is "should it be a deal killer". Answer NO.
                            You've been seeing a lot of SAN 210s on single axle trailers because they are perfectly capable of the task. My 2004 210 is on a single axle Ramlin. I towed it to KY last year (about 425 miles each way). Keep up on the maintenance and you'll be fine.
                            I don't think you'll solve the problem you had with a dual axle, you'll solve it by maintaining the trailer. If you have a dual, you'll have to do 2x the maintenance.
                            I understand where you're coming from, I had a wheel come off my trailer on my 96 Sport. IMO you're not going to solve the problem with a second axle.
                            19 SANTE 210
                            08 SANTE 210 ZR6
                            08 SANTE 230 ZR6
                            88 Baja Ski Sport- First boat
                            • Rick
                              • Mar 2004
                              • 1250
                              • San Diego, Ca
                              Manuvering a dual axle trailer using wheel dollys
                              I use wheel dollies to maneuver my dual axle trailer in my garage. Its a 196 and weights 4000Lbs. I back the trailer into the garage jack it up and put the dollies under each wheel. I can then push it back and to the side for maximum clearance. I have 3 inches of clearance with the swing tongue. It takes about 15 minutes for the whole procedure each way. The dollies are sometimes on sale for $40.00 a pair at Harbor Freight
