Correct prop for a 2000 Air Nautique
  • Lvnspeed
    • Aug 2008
    • 393
    • Smith Lake AL
    What is the correct prop for a 2000 air Nautique with a GT40 5.8 PCM motor? Has factoy ballest tank and a flight control tower. I plan to use it mainly for wake boarding and wake surfing. If you need to know more info please ask I will provide it. Thanks for the help
    2003 226 LE
  • Rick
    • Mar 2004
    • 1250
    • San Diego, Ca
    Call delta prop They area a site sponsor
    The people at Delta prop can tell you what you have and what you need. Since you aren't skiing or Barefooting you can afford to increase the pitch of the prop to improve hole shot ans sacrifice top speed. Are you having a problem now with performance? You may have the best prop on it already.
    Nautiqueless in San Diego
    • Lvnspeed
      • Aug 2008
      • 393
      • Smith Lake AL
      No I bought a boat with a blown up motor and the prop is missing off the boat so I have nothing.
      2003 226 LE
      • Quinner
        • 2246
        • Correct Crafts
        Original Prop was an OJ Legend - 4-Blade 13x16 RH-1" Shaft.
        Have one of these on the shelf (used) if you are interested in purchasing drop me a line.
        • NCH2oSki
          • 1159
          • Maryville, TN
          • 2005 ski nautique 206 SE
          The acme 422 4 blade is the updated cnc'd version.
          Prior Boats:
          1999 Ski Nautique GT-40
          www.skiersofknoxville.org
          • 01bigair
            • Apr 2009
            • 97
            • Kirkland, WA
            I have used both of the afore mentioned props on my 01 Air and both worked fine even with 500-1000 extra pound in boat. Acme seemed to get out of the whole a tad bit quicker but the OJ was fine.
