I just had a trailer built for my 2007 SuperAir Nautique 220. I need to mount the bow wench assembly myself. Can anyone tell me the distance from the end of the trailer bunk (where the transom sits flush) to the bow wench? My only other option is to load the boat with the transom flush at the end of the rear bunk and then mount the bow wench assembly at the proper position. Thanks for all help!!!
Not sure if this will answer question but at the end of the boat you should have one to two inches of bunk left. Next your tongue weight should be approximately 10 to 15 % (tandems) of overall weight. The biggest key here is axle to weight ratio thus a 220 will have more of a stern drive axle alignment since your 810 lb motor in the rear of the boat.
RECOMMENDED HITCH WEIGHT PERCENTAGES
TYPE OF TRAILER
PERCENT OF WT. ON TONGUE
Single Axle
10% minimum/15% maximum
Tandem Axle
9% to 15%
Travel Trailer
11% to 12%
5th Wheel
15% to 25%
