Filling Ballast Tanks
  • holdendaniels
    • Dec 2009
    • 29
    • Novato, California
    • 2007 SAN 210
    I have 2007 SAN. Can you fill two ballast tanks at the same time or is this to much draw on the electrical system? And what's the best way to fill the tanks? At idle? or what speeded moving?
    Thanks!
  • Nordicron
    • Sep 2009
    • 557
    • Madison, WI
    I hit all three at the same time no problems! On my 08 SAN 210 the three pumps are wired into their own 20amps circuits so no worry. As for filling them up you pretty much have to be at no wake speed to fill but can empty on the fly.
      • 2908
      Filling all three at the same time is no problem but I would wait a second between turning on each pump. If you push down all three at the same time it might drop the voltage and pop the fuse on one or two. I tend to use one finger and to from pump to pump instead of slamming all three rockers down at the same time.
