Weird Limp mode problem
  • Lvnspeed
    • Aug 2008
    • 393
    • Smith Lake AL
    I have a 2000 Air Nautique with a GT 40 motor. Boat runs great for about 20-30 minutes above 2500 -3500 rpm then it goes into limp mode.
    No check engine lite
    Good oil PSI 50- 60 psi
    Water temp is about 150
    new cap and rotor
    new plug wires
    new motor
    Shut off the motor then start it back up and it runs fine.
    I unhooked the the oil PSI switch no change. So I hooked it back up.
    Any ideas? I have read that it could be the oil PSI switch, water switch (where is it?), or it could be some manifold switch (where is it?) Can anyone tell me the the part numbers?
    2003 226 LE
