Is the tower of 226 low than 210?
  • hiro
    • Nov 2004
    • 10
    If low, is there any problem?  Is the higher of a tower good?
    Does some use of the boat in the sea have a problem?
  • Rick
    • Mar 2004
    • 1250
    • San Diego, Ca
    Saltwater corrodes the engine components faster. If you use it in the sea, I would recommend a closed loop cooling system and rinsing all the salt off after each use. There is also a product called MST Guardian that you can use instead of a closed lop system. Tower height differences are no big deal. The higher the tower the more the rope pulls you up.
    Nautiqueless in San Diego
    • hiro
      • Nov 2004
      • 10
      Rick : Thank you for information.
