They are wired for a momentary switch. He added the extra leed so that I could hook it to the throttle switch, "Its the Grey insulated cable thats wrapped in a circle" Im sure he would do this for you if you needed or you could do it yourself im sure with out any problems
Ok Im trying to run a wire into the flat bar on my FTC tower. The bar that has the board racks on it. Im instaling a Power Flag and need to run a wire loom threw the round bar and into the flat bar.
Im thinking I will need to drill a hole threw the round bar run the wire loom up to the flat bar and then drill a exrta hole directley threw the round bar and into the flat bar and then run the wire into it. Then I will need to put a plastic plug to cover the hole that I use to drill threw the tower with.
Option #2 I could drill a rather large hole in the flat bar close to the round bar on the inside of the tower, I would use this hole as a opening to drill into the round bar of the tower. And the use a plastic plug to cover the hole I drilled.
Im thinking it would be better not to drill all the way threw the round bar on the tower and the flat bar would be the better way to access the round bar.
The Power Flag is going to be mounted on the rear leg round bar leg of the tower, Its the leg that sticking up in the photo's
Just wanted to throw it out and see if any of you had any better idea's or ways to tackel this
So I finished the install yesterday and everything went as planned.
The flag goes up and down perfict! The button thats on the throttle works perfict. I was so happy to see it go up and down on the first try it was great. The tower monting location worked out great. I had to put the bimini up and load my wake board on the racks just to make sure It wouldnt get in the way of anything.
Ill post more photos soon. It got dark and I couldnt take any good photos of it up
$10 says that CC would sell twice as many boats at each of their boat shows if they had whitechocolate's boat on display there with all his gismos and gadgets.
I think you need to slow down on the inventions, I'm starting to feel like an idiot here while I continue to try to get a stain out of the bow. :lol:[color=blue][size=2][b]I Nautique, therefore I am.[/b][/size][/color]
