My 93' has an interesting warble when in-gear and idling upto 1500 rpm
  • pdxCC
    • Aug 2009
    • 143
    • Portland, Oregon
    • Current -> 01' Air Nautique Previous - 93' Ski Nautique
    I got my gal out for the 1st day of te season and thanks to the knowledge on the board she started on the first turn of the key.
    I did hear a warble in the drivetrain and I wanted too see if anyone else has ever heard something similar. It starts at just above idle when in-gear and then continues upto 1500rpm. It is probable a 10-hertz shimmy/warble. Nothing is grinding or squeeling and there is no discerable vibration. It's likely just the prop in the water eh?
    Any thoughts?
    My friends 92' sport had a similar sound when weighted down.
    ____________________________________________
    Current Boat --> 01' Air Nautique (April 12' to current!)
    Previous Boat - 93\' Ski Nautique Closed Bow ( Sept' 09 to March 12')
  • MattieK27
    • Apr 2010
    • 258
    • Chicago Burbs
    • 2011 X1
    Is the prop tight? Just a simple thing to check...
    • WakeSlayer
      • Sep 2005
      • 2069
      • Silver Creek, MN
      • 1968 Mustang
      Probably a good idea to check your prop shaft alignment too, 17 year old boat may well need it.
      the WakeSlayer
      1968 Correct Craft Mustang
      • pdxCC
        • Aug 2009
        • 143
        • Portland, Oregon
        Mattie - Good idea. I can do that!
        Slayer - I am not a pro but I love to work on things. Is this the alignment process that you do with the feeler gauge at the coupling while rotating the shaft at the prop or would I need to drop the shaft and spin it on a lathe with a gauge (which I don't have access to)??
        I think there are a few threads on these so I might be willing to try.
