Keyless ignition
  • bxroads
    • Jun 2007
    • 15
    Keyless ignition
    I’ve a 2004 196 SE and I'm contemplating the Mercury keyless ignition system (because I can’t keep the factory keyed ignition tight, you have to reach under the dash and hold it to keep it from turning. My wife (and driver) isn’t excited about doing that). I can’t seem to find the Mercury switch’s owners manual online and I’m wondering does it have the accessory position (for the radio). I can’t determine from the picture.
    Has anyone tried one of these switches?
    Clint
  • RyanATX
    • Jun 2005
    • 75
    generally the way it works, you input your code, push start to "enter" the code... and that also puts the boat in a "key on" position. YOu would then push start again to start the engine. This may not be the case with that specific model ignition, but it is the case with all of the other keyless boats i've driven.
    • 2Tuff
      • Jun 2008
      • 31
      I have no experience with that system, but from the looks of the picture it appears that it has a "run" button that would power the boat and accessories up, then push start to engage the starter.
      • WA-H2O-SKI
        • Jun 2009
        • 77
        • Orondo, WA
        • 2017 Ski Nautique 200 Team - Current Boat
        Seems like a lot of Do-Re-Mi
        Seems easier to just fix the ignition from sliding around in the dash. Can't you just get a large star washer to bite in and stop it from loosening? Or teach the wife to turn less hard?
        My wife does like the keyles on our 196 LE.
        -Steve
        2003 Ski Nautique 196 LE - Current Boat (Star Gazer w/ ZBox)
        GOODE Flextail 66.5 - Powershell 5 Bindings (LFF)
        PB: 2 Balls @ 39.5' OFF (34.2 MPH Zero Off) Big Dawg Broho Tournament Summer 2015
        1987 Dixie Super Skier 299 - My First Boat
        1987 Barefoot Nautique - Brother's Boat
        1985 Ski Supreme - Dad's Boat
        • teamseal
          • Dec 2006
          • 384
          • Panama city, Florida.
          • 2009 196 ZR-6
          I would say that the Merc keyless is already installed!!! Clint how is it? I installed a similar one in a 95 SNOB while I was in The R&D dept. It was a easy instal and worked well for many years as that old SNOB was one of our test mules!!
          • bxroads
            • Jun 2007
            • 15
            Jody knows me well. Normally grass doesn't grow under my feet and the switch would already be a done deal. But for change, its still status quo. I'll probably try an upgraded metal switch before I go the push button route (as you suggested).
            • holdendaniels
              • Dec 2009
              • 29
              • Novato, California
              • 2007 SAN 210
              Please let us know, what ignition switch you end up installing. I am having the same problem with mine and reluctant to buy another factory ignition switch. I am sure there is something better out there.
