After pulling for a while, the throttle will get stiff (difficult to push forward). The longer I let it go, the stiffer it will get until you can’t even get on plane. I fix it by turning off the ignition, putting it in neutral and pushing the throttle full forward. I don’t have a good understanding of how the PP works, but I assume it is unwinding a cable. I know it’s the PP because I never have this problem when the PP is off.
I never felt this was much of a problem because it didn’t do it very often, but it seems like the problem is getting worse.
I have the Wakeboard Pro ST300 Paddlewheel if that helps
Sorry, I meant to put this in the maint area and I dont know how to move it.
