Is the PME box the same as the "Faria Gateway Box"? If not, where is the the Faria box located and what is it's purpose?
The PME box (on my 2009 230), is under the SS panel mounted under the dash. It houses the push button circuit breakers for most functions. I believe the Faria gateway box is mounted separately, but not 100% sure on that. I know I just had my PME off to put a larger amp breaker in the 12V/transom light spot. My Shadow casters were popping the 7 amp one. Hope this helps.
Mike
